Adams574
- Jul 2, 2014
- 2015 Viper LE Mpi turbo 162
2012 Nytro MTX 153
2009 Nytro XTX 144
Previous
2009 Summit 800
2008 Summit X 800
2007 Apex warrior
2007 Summit 800
2006 Summit 600
2006 MXZ Renagade 600
2004 RX-1 Mountian
2002 RMK 800
1996 ZR 580
1988 Cougar 500
1985 kitty cat
I was down at my local Yamaha dealer today ordering parts for my viper and he mentioned an upgrade to my spring ordered MPI trail turbo. He was under the impression it was an addition of a intercooler, fuel pump and a different waste gate. In total making it a full stage 1 kit capable of 7-8# and 200-210hp on pump gas.
I have been surfing the MPI website but have not found an answer.
Any intel would be appreciated.
I don't believe that is correct... it will be lower boost 5 to 6, no intercooler. You are better off calling them at MPI.
TD Max
Non intercooled "base" kit with a new electronic wastegate control. The unit adjusts directly to manifold pressure so the more baro (sea level) the less added boost and when in the mountains it runs more boost to adjust to the same total pressure/MAP.
If you run a boost gauge you will see it, but otherwise the operation should be seamless.
Adams574
- Jul 2, 2014
2012 Nytro MTX 153
2009 Nytro XTX 144
Previous
2009 Summit 800
2008 Summit X 800
2007 Apex warrior
2007 Summit 800
2006 Summit 600
2004 RX-1 Mountian
2002 RMK 800
1996 ZR 580
1988 Cougar 500
1985 kitty cat
It's a kit in addition to the non inter-cooled $2000 turbo spring order. Dealer was vague on price of the upgrade but was happy to install for the same price.I don't believe that is correct... it will be lower boost 5 to 6, no intercooler. You are better off calling them at MPI.
matt@mpi
- Feb 10, 2011
The spring turbo deal was for the MTX only. The trail turbo was just released a few weeks ago. I think you have a Mountain kit ordered. The difference between the two is just the electronic boost controller. Its more critical to control boost at sea level that it is in the mountain from a safety stand point. But from a performance stand point it more critical to boost control in the mountains. This electronic controller can be added to any turbo. The kit is upgradeable to 240+ hp. That would require a intercooler, fuel pump, extra injector, and a different waste gate. To run that on pump gas would require a head shim.
Adams574
- Jul 2, 2014
2012 Nytro MTX 153
2009 Nytro XTX 144
Previous
2009 Summit 800
2008 Summit X 800
2007 Apex warrior
2007 Summit 800
2006 Summit 600
2004 RX-1 Mountian
2002 RMK 800
1996 ZR 580
1988 Cougar 500
1985 kitty cat
Yes that is correct I do have the 2015 viper mtx 162 ordered. On top of that I paid $2000 for a spring surge Mpi turbo to be included, it was refered to as a "trail turbo" at dealership not a full stage 1. My question is whether or not Mountian Performance Inocroprated has an upgrade Kit to the turbo I orderd. The addition of a inter cooler and such? So far I have seen nothing on the website and Im sure my friends as well as many of you are intrested in knowing. Sorry for the confusion.
matt@mpi
- Feb 10, 2011
Yes we just finished welding over 100 intercoolers up over the last week in preparation for this. The "stage 1" upgrade will include an intercooler and a high boost wastegate. Depending on your overall goal it may require fuel system upgrades ie, fuel pump, 4th injector etc. I will post more detail info soon.
Adams574
- Jul 2, 2014
2012 Nytro MTX 153
2009 Nytro XTX 144
Previous
2009 Summit 800
2008 Summit X 800
2007 Apex warrior
2007 Summit 800
2006 Summit 600
2004 RX-1 Mountian
2002 RMK 800
1996 ZR 580
1988 Cougar 500
1985 kitty cat
Matt thank you for the update. We're all chomping at the bit here.View attachment 98770
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
- 2015 Viper MTX 162 Turbo
Back up sled AC M7
Awesome just what i was waiting to hear. Do you have a price on the kit that will take the "power surge kit" and make it a full stage 1View attachment 98770
