pat the rat
Did anyone notice the 2 rear wheels are molded together as one wheel,the rep pointed that out to us,first time i see such a setup,does make sense though
Yamacat21
It is the same setup cat has been running. I am thinking I will be looking for a 4th wheel kit before mine even sees the snow.
Yes this is called the TriHub at Cat. Bad idea since if one bearing goes it takes the other one with it.
pat the rat
I kinda thought about that when the rep showed it to me,but its the first time i see this
DeerHuntr
So does the fourth wheel kit replace the trihub all together or just add outside wheels
Yamacat21
I've seen them both ways but you are better off doing a full replacement with slightly larger wheels. That's my plan anyway. Will try to find the web sites again.
Some kits get rid of it and some just add outer wheels. Maybe they will be gone on our sleds. The RR doesnt use TriHub. 4 wheels on 14's.
