AB Ries
- Dec 15, 2020
- Ab
- 2007 Venture Lite
Hello all,
I just bought a 2007 VL (with less than 1700km on it). Took it out for the first ride today and I'm already looking for ways to improve it. Wider skis will likely be on the menu but one of the first things I want to do is install a skid/ float plate. A local wrecker has a plate from a phazer mountain lite but was unsure it would fit. Another website offers a Skinz Protective Gear plate and says it will fit the VL although the manuf website just mentions the Phazer.
I'm hoping that before I order someone might be able to confirm whether the phazer plates would be the same as the VL?
Sorry for the long winded first post! Thanks!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Lots of info already on here about that. Search is your friend.
https://ty4stroke.com/search/2103761/?q=float&o=relevance&c[node]=99
AB Ries
- Dec 15, 2020
- Ab
- 2007 Venture Lite
I have done a fair bit of reading here and elsewhere. I was just hoping for somthing a bit more definitive than what I've found thus far. Thanks!Lots of info already on here about that. Search is your friend.
karl
- Dec 9, 2007
- Whitehorse, Yukon Territory
- 2015 Phazer XTX
I can't be definitive for you because it has been years since I did a bunch of custom work on an MP. I can tell you that the chassis is a full 2 inches wider under the motor, from the tunnel to the front clip. the front clip fits the phazer front suspension parts.
The best things I did to get the sled up on the snow were Simmons Gen 2 10" wide skis and a 16"x159"x2" track
AB Ries
- Dec 15, 2020
- Ab
- 2007 Venture Lite
Thanks!
- 28K
