Water Temp Gauge Install --- Copper Tee?
Grimm
Ottawa, Ontario
Canada
2018 MXZ 850
I'm looking into installing a temperature guage for next year and am having some thoughts on fabricating an adaptor tee to accomodate the sending unit for the guage.
I am not comfortable in spending upwards of $25 for a custom made unit, especially when the whole guage/unit only cost me $10.
After reading through several posts, I have not come across an idea using a copper tee that plumbers use. I purchased a 3/4 X 3/4 X 1/2 copper tee for $2 which seems to do the trick. I am a bit leary at the durability of my system and my concern is that it may burst/leak where I have screwed in the adapter. I had to cut the threads with the adapter, as I don't have a tap large enough to cut threads into the copper.
Has anyone tried using a copper tee with success/failure?
Here is a pic of the setup:
When I was looking at the temps gauges some guys where using brass t-fitting and just adding a couple of inches cooper pipe to the ends. With the brass T, I think they were able to thread the sending unit right into it.
It was on the TY site. Have to look it up again.
I haven't found a brass fitting that I thought was good enough. What I found was was a 3/4 X 3/4 X 3/4 inch brass tee and then I would have to buy another 3/4 to 1/2 inch reducing coupler to accomodate the sensor. I felt that the whole setup would have been too cumbersome and heavy to mount.
This copper tee is much lighter and I'm gonna give it a try.
The discharge line on mine is 1" (vs. 3/4") It seems to me like 3/4" is a fairly significant restriction in the line. By the time you get that element in the flow and include the line size reduction, I would be worrying about causing an excessive flow restriction.
I ended up using a 1" metal underground sprinkling tube coupling with a 1/8" half coupling brazed on. Those metal sprinkling couplings are very thin and don't restrict things much at all. Worked good all last year.
Todd, I measured the actual inside diameter of the copper tee and it was larger than the 3/4", more like 7/8".
A lot of guys here have done similar mods and I haven't heard yet that it has affected their coolant flow, but I will definately keep an eye on things, for sure.
Familymans rx1 turbo had that exact same setup, and it worked fine. I may try and steal it from him now that I am thinking of it. Maxdlx
