dirkdiggler
Suspended
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Is that the purple polish that you use after the green cleaner? Stuff works awesome and very little effort for the shine too.
dirkdiggler
Suspended
sorenson1610 said:Is that the purple polish that you use after the green cleaner? Stuff works awesome and very little effort for the shine too.
Yes
SledNeck91604
shaddow44 said:Are you noticing the fine scratches under florescent lighting? If so push it outside and see if you notice them....I find Florescents show every flaw..which can be a good thing or a bad thing.
Is that why i'm still wet sanding after a month...
TVBrian
- Mar 17, 2009
- Port Perry, Ontario
- www.portperrysnowmobileclub.com
SledNeck91604 said:shaddow44 said:Are you noticing the fine scratches under florescent lighting? If so push it outside and see if you notice them....I find Florescents show every flaw..which can be a good thing or a bad thing.
Damn.... that thing is gonna be SHINY!
07AttackGT
When u guys are sanding how do u work around the decals! are u removing most except for the neccessary ones! Are u using a block with the sandpaper any tips! is there a big difference in the finish if I just polish it as opposed to sanding it and then polishing thanks
