What will I guy need to monitor with a supercharger on the Apex? I assume you will need to monitor water temp and super charger oil temp but what about:
Boost?
since this determined by pulley size is there any need?
Air/Fuel?
Will a person need to adjust fuel mapping via a EFI control box for the stock pump and/or an addtional pump
Exhaust temp?
Would knowing this replace the A/F guage and help determine if there is predetonation happening?
The reason I ask is that I have an avenger guage off my 2 stroke and I could use it to monitor water temp, and supercharger temp, as well as EGT's.
I'm a 4 stroke newbe and I'm trying to determine if my avenger is of any use, and if not, what guages I'm going to need
Boost?
Air/Fuel?
Exhaust temp?
SUPERABE
- Jan 6, 2005
You can never have to much info. We recommend a min of 3 gauges: most important is water temp, next blower oil temp, then wide band a/f ratio. Exhaust temp is good as a reference but not absolutly necessary because of the acuracy of the wide band o2. If I could I would have a wide band on my two strokes and chuck the egt's in the weeds.
monker
