you have a PM......
LazyBastard
Grassfirebob said:I needed the longer track, and 2-up of the venture but never understood why the "bigger" sled comes with the "smaller" engine. What was Yami thinking?
Passengers compromise handling, so its a safety consideration.
Skydog
05 RX1
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Hmmm, what you haven't told us is your requirements other than the cost. Do you want to be first across the lake? Is fuel mileage important to you? Do you want a longer track 136" model or a 121" model?
You need to give us some more information because you should be able to find an 05 RX-1, 05 Rage, and an 05 Vector for under $5000.
Superman
- Jan 21, 2005
- Gaylord MI
- www.lakeffectsnow.com
RX-1. The 05 flat black looked pretty cool.
evilstevie
Is there a ton of diff between an 05 RX-1 and an 06 Apex? Don't laugh, I'm a yamanoob. The Apex got a major suspension upgrade from 06 -> 07, right? Is it true that the early (03 or so) RX-1's had a poor suspension, but that by 05 they were very much improved? There seems to be a fairly large price diff between an RX-1 and Apex, but I would have no problem on an RX-1 if the suspension was OK. Was the RX-1 considered to be a "rider fwd" sled?
Superman
- Jan 21, 2005
- Gaylord MI
evilstevie said:Is there a ton of diff between an 05 RX-1 and an 06 Apex? Don't laugh, I'm a yamanoob. The Apex got a major suspension upgrade from 06 -> 07, right? Is it true that the early (03 or so) RX-1's had a poor suspension, but that by 05 they were very much improved? There seems to be a fairly large price diff between an RX-1 and Apex, but I would have no problem on an RX-1 if the suspension was OK. Was the RX-1 considered to be a "rider fwd" sled?
Opinions vary but here's mine. The 05 RX-1 was a huge jump in comfort over the 03 and 04's. The Mono shock was a bit soft on the 05's but overall I only bottomed Mine a handful of times that season. Plus the weight transfer of the 05's was awesome, as are all sleds with mono-shocks rear skids. As far as 'calibration' the 08 models with the mono-shock are said to be even better than anything from the 05-07 mono-shock line of sleds. Ergonomics is the biggest difference between the RX-1 Delta chassis vs. Apex chassis. My friend still has his 05 RX-1 and Its still a fun sled to ride. His RX-1 is still Fast and does a hell of alot better on fuel than the Fuel Injected Apex's. 2-3 mpg better in My experience. I used to see 18 MPG on My RX-1 and if My wife rode it she would get a real close to 20. Overall though the Apex line is just a more comfortable sled to ride IMO. But if you ask My buddy with the 05 RX-1 he'll say he likes the ergo's and ride of the RX-1 better. Again, opinions vary.
It's all apersonal preffence.
For me I would get a 06 rage with a bar riser and nytro seat.
A few little mods and you will be beating sttock rx1's and tie some apex's up to a 100.
pro116 said:It's all apersonal preffence.
or a 05 vector with nytro seat, could be stretched........ hmmm, i think i have one of those...... and its for sale....
DoktorC
Now...wouldn't all the same mods work on an RX too? And the 05 is cheaper to start with..leaving some room in the budget for the seat and riser...and filters...and clutching
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Again, thanks to all for your input. I now have some serious thinking to do now. I just found out that my Viper with the rebuilt engine most likely has spun the water/oil pump crank drive gear. This means the motor has to come out and I will need to look for a crank. This is after I just had one of the crank bearing replaced and rebuilt the motor with all new OEM pistons and rings. This really hurts as I have spent all summer rebuilding the motor, completely rebuilding the skid (bushings, wheels, bearings, etc.), having all four shocks re-valved by Pioneer, built a custom seat riser, and polished lots of aluminum.
I do not have the time or energy to take the motor apart again. I want to ride.
So I am left with:
1) Having my dealer fix the motor $1,000 - $1,500 on top of the $1,300 I have spent so far.
2) Buy a used 05' RX1, or 06' Rage
3) Buy a new 06' Nytro or Apex
As far as my cash flow, it might make sense to have the dealer fix the motor, but this leaves me still with a sled that has 7,00 miles on it and that has all four original jack shaft bearings, and drive chain that could let go during first ride.
I ride mostly groomed trails with some off trail every now and then. I love the handling and power of my Viper and hoped the new shock valving would help on rougher trails. I have never rode a 4 stroke but planed to go there when I replaced my Viper. Which might be sooner than later. Oh, and the 05' black RX1 I found has already been sold. Bummer!
What to do? G.B.
So I am left with:
What to do? G.B.
It's all in what you want.i cancelled a pre order 05 rx1 and got a vector.I have had many miles on both and for trail riding i prefer the vector.It corners better and feels a lot lighter.
Again it's a personal prefereance.The vector is about the same performance as the viper but faster accelleration out of the hole.
- 6K
