bush wacker
I got a 2007 phazer fx and i was wonder what kind of cheap mods i would be able to do to my sled for better handling, performance, and better rough trail ridung
ViperMan
- Jan 4, 2004
- Binghamton, NY
- 2014 SR Viper RTX
"Cheap Mods" could be a relative term. You might be better directed defining your budget...$250.00?...$500.00?...$1000.00?...$5000.00? The old adage still applies: "How fast do you want to go? How much do you want to spend?"
Personally I would look at Ulmer Racing and Excell Motorsports at the following links:
www.ulmerracing.com
www.excellmotorsports.com
www.ulmerracing.com
bush wacker
i am already buying a freeride track so the max for spending would be around $500. but i am also looking for little arlerations here and there to help boost the overall sled
terret725
get your shocks revalved. make the sled handle so much better. also a set of aftermarket skis that are more aggressive. stock skis, in my experience, are unpredictable in corner. they either push, slide then grab last second, or go where u want them. most of the time its the push. another thing id look into is the ulmer clutch kit. as for the free ride track you could most likely get a track off a 2004 Pro Xr 440, 1.75 inch, or 800 1.325. for alot cheaper. both are 14 x 121 so they will fit without a problem.
bush wacker
where would i be able to find a polaris 800 pro xr track i cant find one
irace
- Sep 2, 2008
I have a track off '04 440 proxr for sale- 1.75" lug
Like new cond. it was drilled for studs but never studded.
$300 + shipping
$300 + shipping
bush wacker
would a 1.75 fit under a phazer
terret725
yea a 1.75 will fit. i have the same on on mine with still plenty of room
beaveman
irace do you still have that track and were are you located
bush wacker
i am able to get the polaris track but i was just wondering if anybody has used a 800 pro xr track before
