Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
After starting my sled in my garage trying to fix my hid light, I noticed on the forth time I started my sled oil just started to pour out of the bottom. I checked the oil filter and hoses and everything looks good. A little help please what to check next? No antifreeze just straight oil.
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
Open your air box and see if oil is coming from the oil reservoirs breather hose. Oil may have been a bit over filled
Being pushed out breather? Is the vent side plugged?
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Have changed your oil filter lately, Is the old seal still stuck on there?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
If it's none of the earlier mentioned info check your lower oil line from the reservoir. The elbows are known to crack.
Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
Yes i did check the vent and and the lower line from the tank. I put more oil in the sled and started it up again and the oil is pouring out some where on the top right hand side of the sled.
Old Thumper
Sounds like the oil return hose that sends oil back to the can.
canoehead
- Jan 14, 2011
- NE, Alberta
Did you open the airbox?
