rxwhopper
just thinking i should do a service and looking under the cooler and seeing the super under there. what all has to be removed to get at the filter?
Ted Jannetty
rxwhopper said:just thinking i should do a service and looking under the cooler and seeing the super under there. what all has to be removed to get at the filter?
Intercoooler and supercharger, you might be able to sneek it out by pulling the battery and tray before the supercharger but not sure.
If you don't have a lot of miles on it, You could just change the oil frequently, Yamaha Suggest only changing the filter every 4000 miles and the oil every 2000.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
With a little patience you can get the filter off without removing the supercharger. It is TIGHT but it can be done. I hope the filter has been changed before and the guy who did it didn't tighten the heck out of it when he put a new one on or they can be a real pain in the a$*!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I change my filter without removing the compressor, no problem. Just remove the battery, battery tray and the intercooler.
rxwhopper
thanks, sounds like fun
bottlerocket
Just think of the smile you have when you ride it all season. 2 ~ 3 hours for the oil change is worth it !!!!!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
cire said:2 ~ 3 hours for the oil change is worth it !!!!!
That must be with a 1-2 hour break, huh? lol
bottlerocket
Round about with picking up the oil and filter but maybe we can have a annual oil change contest and you can use my sled in the competition 1CS1CrazySledder said:cire said:2 ~ 3 hours for the oil change is worth it !!!!!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
cire said:Round about with picking up the oil and filter but maybe we can have a annual oil change contest and you can use my sled in the competition 1CS1CrazySledder said:cire said:2 ~ 3 hours for the oil change is worth it !!!!!
LMAO....yeah, RIGHT. LOL
I've had my sled apart soooo many times, I have it down to a science now.
