Whats the best bang for your buck??
I am not happy with the MPI unit, I am looking at a RB3 or a Power Commander with add on needed to control boost and timing... anyone else have ideas??
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Just want to post so I can follow this.
APEX 06 said:Just want to post so I can follow this.
Ditto
spddmon
the other thing to consider is on trail adjustability the rb3 is nice but you need a laptop to tune that can be a pain when out on the trail
spddmon said:the other thing to consider is on trail adjustability the rb3 is nice but you need a laptop to tune that can be a pain when out on the trail
I was hoping to tune this thing in on the Dyno and get the map and fuel delivery as spot on as I can.
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
The biggest downfall with the gems for me was it gets wet so easily i ruined another one last week Im thinking about switching to rb3 i only ride at sealever so i shouldn't need to adjust it after its setup.
I found the boondocker box to be the best and most adjustable on the trail and was bulletproof for the 7000 miles that I used it now my buddy uses it on his stage 2 S/C with great results. If you want to play with timing I would use the PC111 but it will be alot more tuning and you will need a laptop to make changes. If you get your hands on a boondocker I will be able to give you a base set up for your sled, just need to know how much boost you are running and if you have a head shim or not.
stone88 said:I found the boondocker box to be the best and most adjustable on the trail and was bulletproof for the 7000 miles that I used it now my buddy uses it on his stage 2 S/C with great results. If you want to play with timing I would use the PC111 but it will be alot more tuning and you will need a laptop to make changes. If you get your hands on a boondocker I will be able to give you a base set up for your sled, just need to know how much boost you are running and if you have a head shim or not.
Where can I get a Boon Docker??, I am running 10lbs with head shim. Will this give me the best fuel economy for trail riding too?
Unfortunatly 10# on a S/C and fuel economy dont go hand in hand, you can expect 80-90 miles to a tank but if your on it alot even less. There are a few used one's out there but you can call boondocker and see if they have some new one's in stock.. I will check with my buddy and see if he wants to part with it as he is talking about going turbo.
stone88 said:Unfortunatly 10# on a S/C and fuel economy dont go hand in hand, you can expect 80-90 miles to a tank but if your on it alot even less. There are a few used one's out there but you can call boondocker and see if they have some new one's in stock.. I will check with my buddy and see if he wants to part with it as he is talking about going turbo.
I would like to see 10 to 12 MPG being gentle ....I dont think thats to unreasonable.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
MrSled said:I would like to see 10 to 12 MPG being gentle ....I don't think that's to unreasonable.
Tom,
I had a hard time getting that on my blown RX 1 on 5.5 lbs being gentle. 10 yes, 12 no.
We just finished the build two weeks ago my former 06 Apex GT with a MPI Stage 1 and the new owner is running 6.5 lbs. Not getting near close to 10 to 12 MP per US G. Maybe 10 miles to a Canuck Gallon. Now mind you we are still tuning it and have been running it a little harder than normal to test things out.
That being said, I have owned a few 4 strokes and have not found an Apex yet that would come within 1.5 MPG of a RX 1 or Warrior.
Stone88 is not the first to say they get a lot thirstier on 10 lbs.
Oh yeah, we are are having a hard time achieving perfection with the Gems. Got a small pop/miss under hard acceleration from a standing start.
Dave
Riceburner said:MrSled said:I would like to see 10 to 12 MPG being gentle ....I don't think that's to unreasonable.
Tom,
Dave
I was going to send the Gem back to MPI and tell them to rework a few things to try and get some better results... Maybe a PCIII with some ad on might be a better bet.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
It might be. I'm just getting started with the fuelie's so I can not give a solid informed opinion. Sorry.
Stone88 has some serious time working with blown sleds I am told and I have also been told by a reliable source he knows his stuff. Time this thread is around for awhile I am sure you will have some good info to help you make a decision
Gems is definitely fussy to tune and sometimes seems to go a little wacky. Not a great combo.
RX 1 seems like a piece of cake compared to an Apex. Sometimes new Technology is not better or easier to use.
If I boost the 2011 Apex I may try the new MCX Turbo this time.
However out on a lake two weeks ago; my bone Stock 2011 SE, my former SC RX 1 and my former SC Apex all GPS ed 170 to 172 KPH on glare ice in 1/4 mile or so. I may just stay close to stock with the 2011 Apex. Its a runner. Stock E-tecs and 800 R's are not a problem over 500'.
Dave
Dave
FLYBYU
you know MPI has a closed loop fuel system out now.
FLYBYU said:you know MPI has a closed loop fuel system out now.
Had no idea. You have any info or a link to the new product?
