muskrat
Hi Ted
Thanks Ted, that makes a lot of sense. I bought a BOV from you like 3 years ago....been distracted I guess. Anyway, where is the best place to put it? I don't really want to cut a hole in hood. Thanks
Mark
Mark
Ted Jannetty
Re: Hi Ted
What Sled do you have, and who's kit
muskrat said:Thanks Ted, that makes a lot of sense. I bought a BOV from you like 3 years ago....been distracted I guess. Anyway, where is the best place to put it? I don't really want to cut a hole in hood. Thanks
Mark
muskrat
cpr
2003 RX1 with CPR kit, it is getting tight in there. I had to modify hood slightly so it wouldn't hit air cleaner, so far it looks stock hood.
MM
MM
Ted Jannetty
Re: cpr
Your probably going to have to hang it off the charge pipe over the clutch guard.
Ted.
muskrat said:2003 RX1 with CPR kit, it is getting tight in there. I had to modify hood slightly so it wouldn't hit air cleaner, so far it looks stock hood.
MM
Ted.
muskrat
bov
OK, that should work. how far from charge tube can the BOV be and still work correctly? I may have to get a steel weldable bung from you, I think I bought an Al2 . I'll check tonight, thanks Ted.
Mark
Mark
Otis RX
muskrat
otis
Thanks otis....
My air cleaner is there. It will almost fit under hood but hits frame and hood. You are right, Ted is great to deal with, I may give him a call. My idea is to run a small piece of pipe off charge tube and put BOV there, above clutch guard. Wonder if that would work. So, where does the vac line connect from BOV. Thanks
MM
Thanks otis....
MM
Ted Jannetty
Re: otis
A short peice of Pipe is Fine, make sure you have room under the hood where you plan to install it.
Vacuum is pulled from the 4 nipples in the carb boots.
Ted.
muskrat said:Thanks otis....
MM
Ted.
looking4speed
Mine is in the charge tube over the clutch guard. There is enough room there but you must loosen and tip up to remove the belt guard.
muskrat
Thank you
Thank you ALL for the help. The research is done . Now the fun part
Mark
Mark
