RobX-1
- Coldwater, OH
RobX-1
- Coldwater, OH
Where is the link
Thank you. I was trying to search it using these no's. 11568-4474723
As far as the link I was looking for a icon, my mistake.
Fast
- Sep 25, 2018
Looking to install new donuts. Which ones are better, oem or copper. From what I am reading copper will last longer but might affect some cracking on the rest of the exhaust. Some one on here said that the new oem donuts come with a new ss screw for the clamp, is that correct & that the new donuts are better than the old donuts that they made. I also here that you should grind off a little metal on the clamp so that they fit tighter.
Fast
- Sep 25, 2018
The original steel worked longer for my 2006 apex titanium were the worstLooking to install new donuts. Which ones are better, oem or copper. From what I am reading copper will last longer but might affect some cracking on the rest of the exhaust. Some one on here said that the new oem donuts come with a new ss screw for the clamp, is that correct & that the new donuts are better than the old donuts that they made. I also here that you should grind off a little metal on the clamp so that they fit tighter.
