ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
If i went to 1" now id simply go 1" ripsaw2 model(without quiet bumps). Keep the 2.86 pitch same. Guys run them and work well. Maybe a tad slower then the 14" hack which I ran on my cat turbo and it did make great speed.
Im thinking more now of gearing down(back to stock 21/41) and aiming for better corner to corner, since I really do alot more of that then radaring these days, and would love to get belt life increase.
Dan
Dan
Byam
Ulmer gave some good info Every sled i know whit hacksaw 2,52 run 11 tooth drivers. I think avid have the 10 tooth driver 2,86 but whit out anti-ratchet.
170plus
- Jan 14, 2004
- washburn maine
- 2021 polaris assault 850,18 sidewinder ltx,14 nitro xtx,06 apex rtx,
have 06apex with 128x13.5 hacksaw with 10k miles on it,gained few miles per hr,also put 144x14" hacksaw on my 14 nytroxtx ,gained 5-8 mph on top,plus less slider stick,2000 miles on it this winter,i really like the hacksaw,most trails the hacksaw hooks really well but 130 and 150 hp is way different than 200plus,i am looking for more top end with my stock 2018 winder so this track post really caught my eye,i trail ride and never stud but love rolling on top
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Where do you get the 11 tooth 2.52 drivers?Ulmer gave some good info Every sled i know whit hacksaw 2,52 run 11 tooth drivers. I think avid have the 10 tooth driver 2,86 but whit out anti-ratchet.
Byam
Avid asphalt driver no anti ratchet. You are gona have to play whit gearing to.... Big wheel instead of tri-hub and bigger wheels in he upper skid is a good mod to do. I will do it this summer
DMCTurbo
- Nov 12, 2005
Does anyone run the Camso durasport .75 full block for speed running?
Sounds like there will be a few guys installing deeper tracks on the SRX. Why not put the word out and see if you can buy someone's take-off.Does anyone run the Camso durasport .75 full block for speed running?
DMCTurbo
- Nov 12, 2005
I may be wrong but I think those 1" ripsaws are only 1 ply.Sounds like there will be a few guys installing deeper tracks on the SRX. Why not put the word out and see if you can buy someone's take-off.
2 ply according to YamahaI may be wrong but I think those 1" ripsaws are only 1 ply.
DMCTurbo
- Nov 12, 2005
Ok the ones I've found online are 1 ply..2 ply according to Yamaha
sledding rocks
a buddy of mine did the 11 tooth 2.52 driver going back a couple seasons ago , didn't last long on the trails , these drivers r much bigger and r exposed , he bent his axle after hitting something , I think for the trail going bigger drivers has no advantage , strictly racing only .Where do you get the 11 tooth 2.52 drivers?
Byam
Still have the shitty speed silent bump.Sounds like there will be a few guys installing deeper tracks on the SRX. Why not put the word out and see if you can buy someone's take-off.
I was just on their website, it states 2 ply.Ok the ones I've found online are 1 ply..
Also, on youtube, snowtrax has a video and the guy says it is a 2 ply.
DMCTurbo
- Nov 12, 2005
Ya I think you are right, I'll stick to the stock drivers.a buddy of mine did the 11 tooth 2.52 driver going back a couple seasons ago , didn't last long on the trails , these drivers r much bigger and r exposed , he bent his axle after hitting something , I think for the trail going bigger drivers has no advantage , strictly racing only .
Yes, looks that way unfortunately.Still have the shitty speed silent bump.
