backchannelmako
- Nov 8, 2014
- Nytro mtx 02 viper
Just picked up a Nytro with 800 miles and not sure what oil has been used in it. Does it matter whether I use synthetic or conventional? Thanks.
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
I use Yamalube 0-40 syn. in my nytro
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Nope doesn't matter I use Amsoil 10-40 synthetic
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Mobil-1 0W-40 full synthetic European formula. Half the price of overrated Yamalube.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Doesn't matter if conventional or synthetic, but sled calls for a 0W30 or 0W40. You will only find "0" rated oils as synthetics. As Irv said, Mobil 0W40 is a very good choice and is especially inexpensive in the US.
greenmachine93
- Sep 10, 2014
- 2008 nytro rtx
i would go with synthetic just cause it wears better, but if the snowmobile leaks oil a little go with conventional oil cause that can fix it, and always get a good filter dont go cheap. alot of time people run the yamalube and that what i run in my nytro.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Just saying.
Here is a VOA (Virgin Oil Analysis) of Yamalube done in 2008
http://www.bobistheoilguy.com/forums...Number=1242718
It does not look like anything that special to me. Zinc and Phos levels (which are the big anti wear materials) are not very high...Looks like a run of the mill oil at best
*** Disclaimer I am not a chemist, engineer or the like but I spend some time on that website***
for comparision
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
I like the high mileage mobil one or Rotella t5 or t6
rotella t5 (semi synthetic
http://www.bobistheoilguy.com/forums...57#Post1791357
Rotella t6 (full synthetic)
http://www.bobistheoilguy.com/forums...Number=2330040
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Do not under any circumstances use a cheeper automotive oil.
As long as you use a good quality snowmobile/quad/Bike oil of the proper viscosity you should be OK.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Uh, rotella non desil oil? Most rotella oil ims high detergent to keep the motor clean because of the low octane (ctane) rating and build up. And also a ton of lubricants to keep motor running after all the detergents go through it
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
Mobil 1 0-40
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Been running 0w40 yamalube. Even at my discounted price though its still 12.50-13.50/lt. Considering my options now. Lots of people run t6 5w40 in cars quads and even a few sleds I'm sure. I personally use it in my can am and my duramax. I'm very tempted to try it in my nytro as well but have enough yamalube on hand for two years yet so I haven't thought real hard about it yet.
ronnie1
- Dec 3, 2007
- St Paul, MN
- 18 Sidewinder RTX SE
THE BEST-Itt's all I useMobil-1 0W-40 full synthetic European formula. Half the price of overrated Yamalube.
- 6K
