stomper
I’ll have to research how to do that.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Correct. Idle would be erratic if carbs were out of sync.Did you seperate each carb from each other?if not I don’t beleive it’s an issue with carb sync.View attachment 153169
stomper
sorry double post
sorry double post
stomper
No I didn’t separate the carbs. All I did was remove the bowls, jets and slides, I also replace the needle and seats with new in all carbs, Cleaned the jets and passages and put them back together. That’s it.
Brotherdan
- Sep 8, 2017
- Belmont,maine
I accidentally replied to an old post did you bypass the tors by reconnecting on the harness side?No I didn’t separate the carbs. All I did was remove the bowls, jets and slides, I also replace the needle and seats with new in all carbs, Cleaned the jets and passages and put them back together. That’s it.
stomper
I will definitely check this out. ThanksDid you seperate each carb from each other?if not I don’t beleive it’s an issue with carb sync.View attachment 153169
stomper
Yes I connected the bullet connectors together on the harness side but it never made a difference.I accidentally replied to an old post did you bypass the tors by reconnecting on the harness side?
stomper
Haha this is getting confusing. Got a couple threads going about this problem. Didn’t mean to do that. I guess I should have posted this on my first thread.
