Northern Sledder
How about painting them, or is that not a good idea?
SledFreak
- Feb 7, 2005
- Ontario. Canada
machzed said:130mm spoked accessory wheel w/6005 bearing:
SMA-8FU38-01
178mm Rear Axle Spoked w/6004 bearing:
SMA-8FU38-02
these are out of the 07 book i have here(canadian book) so they should be current numbers..
Dan
Dan, are these bearings replaceable? OR do you have to buy the whole wheel/bearing again?
![](/styles/vip.gif)
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Replaceable...
Dan
Dan
MyOutdoors
Has slydog released their wheels yet?
welterracer
I called slydog.. they have no idea when they will be in production..
You would sware they are some rinky dink company... How could no buddy know when there stuff will be out.... Ive emailed them a several hundred times with no response..
MyOutdoors
Yeah, I was prepared to replace all the idlers under my skid after the last set of centers blew out again. They looked promising...but got the same answer. I will tell you that I got Fix's 4th wheel kit and hyfax saver wheels and so far so good. 4th wheel kit keeps track aligned and true so it doesn't shift to one side and start to eat the center idlers.
