stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
15,000kms and no plans to change it..... it will run with anything on the trail but, on the lake.....not so much
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
2009 XTX with 23,000 miles, running great.
NS FX NYTRO
2008 fx nytro, 5100 miles. Replaced a arm bushings with oilite, copper exhaust donuts on the way, ski-doo pilot skis, and a little greasing here and there and she runs like new.
I will gladly update the few things I mentioned above to not worry about my top end or crank flying apart like I would on most other 2 stroke sleds. I really like this sled, rear skid could use some work for small bumps, but on par with 2007 mxz I sold.
bimmerwrench
- Oct 19, 2015
- Albany NY
- 2008 Yamaha Nytro
13877 second owner sled still looks brand new
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
31,000 miles 2009 XTX. I'm on my 3rd track, replace bearings when needed, new ball joints and tie rods at 27,000 (these were way overdue at this mileage). Replaced bearing and PTO shaft this year. Also replaced drive axle and cracked exhaust header. Motor runs great, best sled I've had. Been riding Yamahas since 1973.
Past sleds:
2006 Attak 26,000
2003 RX1 13,500
2001 Mountain Max 700 14,ooo
1998 SRX Mountain 23,000 (still running and kickin #*$&@, never been rebuilt)
1995 V Max 600 12,000
1979 SRX 440
1975 GPX 338
1973 GP 338
Past sleds:
2006 Attak 26,000
2003 RX1 13,500
1979 SRX 440
1975 GPX 338
1973 GP 338
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
Oh, by the way I am in the UP right now getting ready to go for a ride today.
yamariv
3230 miles.
One subframe.
One belt.
Two sets of slides
Three sets of carbides(man do Pilot Skis eat carbides on marginal snow)
215 gal of gas
One oil change
A whole lot of fun[/QU
alsops
- Feb 17, 2009
- Headingley, Manitoba, Canada
- liverpool.com
- 2009 Nytro XTX
2021 Sidewinder XTX LE
mcamzr
Let us know what part you are riding and how the snow is??Oh, by the way I am in the UP right now getting ready to go for a ride today.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
Just got back from my ride in the Brimley area and it was spring riding, 60 degrees and bright sunshine. You have to stay in the woods where there is still 1-2 feet of snow but going fast. Pretty sloppy and rough. Anywhere they plowed it's gone. It was a beautiful day but I am afraid it's the end. Just glad to have done it. I will ride a bit in the morning and then go back to Fenton and ride my PWC on Monday. Life is good!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
18,905 miles on my 2010 FX Nytro RTX SE.
Still going strong!
Still going strong!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
17,000 km and still as strong as ever.
New track last year. Replaced just about every bearing - twice at least
How long should you wait to do the pto bearing on the clutch side?
Ms
Ms
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
09 XTX, bought it with just under 12,000 mi. Looked and ran like new! Sent it to Full Power Performance for a compleat build. It made 309 hp on 16 lb boost last week at Dyno Tech! More on tap if I need it. Hope to have the cosmetic part done in a couple week's! Justin said the motor was like new when they opened it up.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I should have checked mine sooner, caught it just in time. The inner cage that holds the bearings was coming apart. Checked my sons with 12,000 miles and it looked pretty dry so we replaced it. You can remove your primary and pop the seal out of the bearing to clean and add grease like you have to on the outer primary bearing on a Doo Doo. I thought this bearing would get oil from engine but was surprised to find it doesn't. It is easy to service if you do it before damage starts like with mine. I posted pics of mine in Nytro section back when I found it in December, if you want to go back and take a look. I have a shop in Fenton where I do sled repair and I am going to replace bearing and seal and offer a set up ready to go if I discover bearings to far gone. I will be recommending this as a serviceable item for my customers.
Dr. FeeLGooD
16144 k. Done for the year.
- 7K
- 9K
- 10K
