getchuk
- Apr 23, 2004
- Sweden
- Sweden
- Vk540
- Norrbotten
This ac/yamaha deal rises alot of questions , one that puzzlez me is why ac fuel inj.
One would believe yamaha knows their own engine, has ac's some benefits that couldexplain this or is it just ac doing rnd for the sled, has it any pros for racing?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I'm at a loss aswell, obviously yamaha has it figured out with their bikes and boats and things, why change for this. It's reprogram able but that's really the only benifit I can think of.
mr. shide
It says on spec page on yami site that its yamahas fuel injection system.
mr. shide
"The Genesis High Performance engine uses Yamaha’s advanced fuel injection system to control fuel flow to the engine. Consumers will enjoy the engine’s spot-on performance and throttle response as a result of the advanced electronic fuel injection system."
This is straight off yamaha's official website under the performance tab for the srviper models!
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Boy I have never seen so many people jumping to conclusions without doing any research.
Daranello
Suspended
journeyman said:Boy I have never seen so many people jumping to conclusions without doing any research.
I think he's commenting on this pix that what in this article of http://osmmag.com/yamaha-2014the-details-and-dirt/
"Surprisingly, the new Viper buggies will utilize Arctic Cat’s closed loop fuel injection system…yeah we are still scratching our heads over that one too."
getchuk
- Apr 23, 2004
- Sweden
- Sweden
- Vk540
- Norrbotten
Yeah, just read cris reeds blog where he says that ac. developed the exhaust and use the synerject ecu controlling. A closed loop fuel injection system, and on snow mag also says its cats system btw cat has their on name on the engine on their website so then they have made their own engine?? Just asking what benefits this system would have? Turbo?
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
I hope they get a better welder. That looks like junk even if it is just a proto type.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Its Yamaha's throttle bodies, with Cat ECU and sensor.
couch
Just thinking the same thing ... just started using a TIG wielder and my wields look better ..... wields in phot look like bubble gum!nitris223 said:I hope they get a better welder. That looks like junk even if it is just a proto type.
00-NUKE
I'm kind of hoping that they do use AC's ECU. Maybe that will eliminate the hesitation in this motor.yamaha1973 said:Its Yamaha's throttle bodies, with Cat ECU and sensor.
Dano
Cat probably wanted the ECU mapping because they plan to add boost to it next year. If they no longer have the suzuki, they won't sit still with a 135 hp 4stroke, thats for sure.
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
You guys gotta remember, this sled is ALL AC made. the only thing in it yamaha is the motor and clutches.
Look at the wire loom,crappy zipties,bolts,nuts,fuse box....everything is exact same as my cat. Even the crappy cat skis!
I agree with Dano about the ECU. Cats setup can be written too and this is why the cat turbo is the best bang for buck to get to 260hp on the cheap,even with all their issues!
Dave at Hurricane is ontop of this already and will be building turbo kits.
I fully expect to see a 2015 Cat turbo utilizing the yammie triple(hopefully yammie too!) to replace the ZUK 1100 turbo like mine.
Dan
Dan
O2 sensor + map sensor = ecu that can, to an extent, accept and compensate for mods w/o fuel worries.
I agree that weld is an embarrassing piece of crap.My buddies 1000 crossfire has mig wire stuck in the welds from factory.nitris223 said:I hope they get a better welder. That looks like junk even if it is just a proto type.
- 7K
