littleredsled
i got all my mods done t my sled and i put a hauck fuel programmer on and air box and i cut out the exhaust so when i hit it when im doing about 30 - 40 mph it kinda stumbles and stutters and doesn't know what to do for a second t sounds like its cutting out a cylinder but im not sure here are no codes coming up on the screen or anything .........
another question when i hit the throttle my fuel programmer just lights 4 of the bars up red to was wondering if anyone else has the fuel programmer and if it does the same thing....
yamadog1
call
i would call haucks talk to pat he can tell you what to do, it may fuel
programmer if not he can help.
**sj**
you need more fuel....sounds like its not adjusted right or working properly
littleredsled
k thanks anyone have the number for hauck?
Yamadog
littleredsled said:k thanks anyone have the number for hauck?
715-234-6195
I am running Gyt-R-Dunn fileters, gutted exhaust and fuel accelerator and have no problems. You cannot get to little fuel because you can't go less than the stock fuel map. I have mine plugged in but am still working on clutching and have not yet started to play with fuel. I am on 07 Attack but ran it last yr on 03 RX-1 with 06 stroked Apex motor with filters, pipe and never had a stumble at stock map or fuel bumped up.
Iceman57
littleredsled said:i got all my mods done t my sled and i put a hauck fuel programmer on and air box and i cut out the exhaust so when i hit it when im doing about 30 - 40 mph it kinda stumbles and stutters and doesn't know what to do for a second t sounds like its cutting out a cylinder but im not sure here are no codes coming up on the screen or anything .........
I had the same problem but I have a PCIII. I added 13% fuel to the 2% and 5% throttle position between 1250 and 4250 RPM's. The problem does almost not exist now.
littleredsled
thanks for the number ill give him a call tomorrow
- 147K
