dyeager
Anybody know or done this already?
sherlock29
nope... phazers have a 14"(+) wide tunnel... all others 15"(+)...
dyeager
I'm talking about front suspension. Found out that it would. They are slightly longer but will bolt up, and are obviously a considerable improvement over the stockers.
RayKnobs
When you says "suspension" are you referring to the shocks only?
dyeager
yeah, sorry for the confusion. I'm talking about swapping the gytr clickers for the stock shocks in front.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Make sure the compressed and uncompressed lengths are the same, at least the compressed length should be close, if the compressed length are shorter on the Apex shocks you may bottom the sled on the belly pan.
Amo
They will work, they are about 1/2 to 1" longer so back of the spring collars. Also, the bushing mount may need to be ground down if its too wide by 2mm on either side (depends on year of shock), but its a simple mod. They work real nice on my phazer.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Great info
np342403
Does anyone by chance know the compressed and extended lengths of the stock MTX front shocks?
