SUC_doo
- Jan 4, 2017
- Collingwood, Nova Scotia
- 17 sidewinder rtx, 08 apex ltx gt, 01 formula deluxe
I was def faster out of the hole on bare ice with the 33/35. Mileage hurt some for sure when trail driven.Don,
Why do you want to slow the sled down going from a straight 35 to the 33-35? Taking away helix will not make it quicker, but slow it down and it will hurt the mileage too over the straight 35.
You want faster? Put a stock muffler tune in it at the least. I know a guy that can help you out there, I'm heading out tomorrow to put one in Josh's new Winder for his trip this week to northern WI.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
But it was snappier corner to corner?I was def faster out of the hole on bare ice with the 33/35. Mileage hurt some for sure when trail driven.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I've been wondering the same thing. Interesting comment on the lower fuel mileage when trail driven.But it was snappier corner to corner?
I wonder if everyone else has been experiencing a drop in fuel mileage on the trails with a reverse angle helix?
I guess it stands to reason that if you're loading the motor more at lower track speeds with the reverse angle helix running a shallower angle at the start that the motor is going to be spinning a higher rpm before the secondary starts to downshift.
Never Satisfied
- Oct 10, 2017
- Madison
You are not loading the motor more with a shallower helix, you are shifting slower. Also it will back shift progressively faster as the lower the angle the quicker the backshift.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
On that 200 mile day on mine. I averaged 15.2 mpg on my first full up. Is that good, bad or average? Like I said, we rode in poor conditions most of the day at various speeds. Next week in Maine will tell how the setup really works.I've been wondering the same thing. Interesting comment on the lower fuel mileage when trail driven.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
I would say that's pretty good.
Never Satisfied
- Oct 10, 2017
- Madison
Way better than I have ever gotten! When running hard with 800 2 smokers I get just a hair better than they do, looking for gas at 100 miles.
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
I have/had a stock RTX with full TPI kit & 35/39 helix. I went 112 miles on a tank with no fuel warning on. Now I’ll grant you that it was an easy day on the throttle. As far as slowing the sled down with the reverse angle helix...i just don’t see it. I’ve run 122-123 on the SPEEDO. I had lots of help from NOS-PRO, but the sled rips!I was def faster out of the hole on bare ice with the 33/35. Mileage hurt some for sure when trail driven.
NOS-PRO put an EVO stage 3 tune in it this week, so, now I’ll get to have some real fun. CHEERS!
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
The reason you are seeing lower mpg readings is the shallower helix is holding the sled from upshifting resulting in higher mid range rpm's. What I didn't like about the 33/35 helix was when trail riding it would downshift too quickly and then try to upshift then downshift again. This was all happening at lower rpm's and I felt I would prefer if it would just upshift quicker and hold a steady rpm. It was too herky jerky for me.I've been wondering the same thing. Interesting comment on the lower fuel mileage when trail driven.
Jafo1970
- Dec 2, 2016
- oshkosh, wi
- 17 sidewinder, doo 850
I ran a 35/39 helix with TP clutching when I was running my evo tune and would get 15.5mpg running with my 800etecs bud and they were getting 12-13. The 35/39 helix gave me about 1 to 1.5mpg better than the straight 35.
XP123
- Dec 25, 2016
- Chautauqua NY
I'm thinking it had to do with the steeper finishing angle. How were your WOT rpm's? Were they lower than stock?I ran a 35/39 helix with TP clutching when I was running my evo tune and would get 15.5mpg running with my 800etecs bud and they were getting 12-13. The 35/39 helix gave me about 1 to 1.5mpg better than the straight 35.
Jafo1970
- Dec 2, 2016
- oshkosh, wi
Ran straight to 9000 and stayed there till 129mph. Never ran it more than 1500' or so. Ran 122mph in 1000'. Stock secondary spring shimmed. Wish I could get my new setup to work that good.I'm thinking it had to do with the steeper finishing angle. How were your WOT rpm's? Were they lower than stock?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
35/39 is a far cry from 33/35. You are riding always on MORE helix then stock, where the 33/35 you start shallower and at low speeds are shallower.
Reverse angles have shift characteristics I do not like at all. They(flash) overev initially.
Jafo1970
- Dec 2, 2016
- oshkosh, wi
Possibly, with my softer evo tune last year it didn't over rev and I loved the way it ran, but yes this year with the hurricane 290r it did. Evo redid there tunes this year to pump up the middle. The reverse angles were a bandaid last year.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
I have the TP clutching with 35/39 also and my RPMS have always been a tad low.I'm thinking it had to do with the steeper finishing angle. How were your WOT rpm's? Were they lower than stock?
Did you ever have to adjust weights in TP set up at all to get to this?Ran straight to 9000 and stayed there till 129mph. Never ran it more than 1500' or so. Ran 122mph in 1000'. Stock secondary spring shimmed. Wish I could get my new setup to work that good.
I'm going to be trying taking out tip weight to up the RPMs (thanks to @jonlafon1.) Without the TP orange secondary spring I was at 8500. With it was at 8700. Have only ever seen 108 on Speedo. Some of it's probably my fat arse , but I still should see more regardless.
- 6K
