CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
This is what cable scratchers have done to my rails and why I’ll never mount any type of scratchers to my rails again.
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
I'm wondering if any type of scratcher will cause nicks in the rails. All the sleds I've used cable scratchers on did not have painted rails. Time will tell with the BRP tunnel scratchers.
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
I installed the cable scratchers that Mount on your A arms. They come with rubber hanger when not in use.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Who makes those a arm brackets?
Derek Fosbury
- Jan 18, 2021
- 2022 Sidewinder S-TX GT
2025 SRX
- Sledding Location - Fenelon Falls, ON
I installed the cable scratchers that Mount on your A arms. They come with rubber hanger when not in use.View attachment 160462 View attachment 160464 View attachment 160465
I really like that concept - what brand are those?
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
They were from QualiPieces, but I don't see them on their website. I see the rubber hanger.I really like that concept - what brand are those?
Derek Fosbury
- Jan 18, 2021
2025 SRX
Thanks, good place for me to start!
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
Update, I installed the stainless I bolts on my skid for my scratchers to hang in a they worked, kept my scratchers in place this past weekend, thanks for the Info TY members.
SAB1
- Mar 1, 2011
- Tuftonboro NH
2010 Vector GT
2006 Apex
Im going to look for them also. I bought a pair of quick release brackets from Straight Line for my Apex. Ill have to modify the rubber inserts as they probit the bracket from going all around the tube. I like the quick release feature of them though.
Pictures would be great to see set-up
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Finished the season with the ski doo double spring rail mount scratches and no complaints, stay seated in hanger when not in use, no scratches on rails, work great.
SAB1
- Mar 1, 2011
- Tuftonboro NH
2010 Vector GT
2006 Apex
Here is my setup on Sidewinder. I dont like drilling holes in rails when I dont have to. I got 2 pieces of aluminum and drilled holes and ran bolts thru the window cutouts in the rails, I glued rubber on the insides of the aluminum plates so no scratching on the rails could occur. I used Stainless washers on the bolts as spacers on between the plates to fill the void from the window. The stainless 1/4 inch eyebolts are thru the rails in existing holes in the rails. Originally the plates were orange but the paint peeled off. I guess I need to use Zinc Chromate on the aluminum before I paint the orange. This system has 4 years on it. In the stow position they have never come out of the eyebolt when under way. No issues bumping track. These are Duraflex scratchers.
Just an FYI to anyone installing scratchers. Just be mindful of clearance to other suspension parts, such as wheels, when the suspension is fully collapsed.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Travis at BOP has those same brackets that come with his scratchers when purchased from him, have them on my XTX and yes leave them deployed all the time other then going in and out of the trailer.Here is where I run mine. Made my own brackets. No drilling, bolt right on!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
When my tips wore down I also did the fender washer, a lot cheaper then replacement tips and still does a great job.Actyally mine stay down all season!
Some guys have put a clip on the ski to hold them. No issues burning up the tip neither. My buddy took the carbide tips off an put a bolt with a fender washer an that works good too.
