Charged RTX
I have been searching the forums and can't find the specs on these belts. Does anyone know where to find this info? I want to try a softer belt this season and am considering the XS 805. I think it is a little wider which I like but I do not know the length compared to the 8dn. I have also heard that there are a couple more XS belts that work.
ptt
Guest
I have the info on those belts in the shop I'll Pm you tomorrow.
Charged RTX
Thanks Scott
Len Todd
SnowTech guys are also saying 8DN is too hard. They are recommending Dayco Ultimax 3 part number 138-4432-U3. They say it is softer and only slightly longer.
Charged RTX
Is the Ultimax 3 a downgrade from the XS?
Len Todd
Not sure what XS stands for. Are you talking about a Dayco?
Dayco has an HPX version that is supposed to be for High Performance Extremes. But, what we are figuring out is the high performance belts are made for longevity. By doing such, they give up the grip of a softer belt. The theory is; The 8DNs are said to more frequently slip unless we bring up the twist. But when you bring up the twist, you delay the shift. It is all pert of finding the ultimate compromise of combinations to fit our own specific needs.
Of course, if you do not clean a new belt before it is installed it really does not matter. The new belts have mold release lubricant on them. You need to wash that off with some high powered soap (e.g. 409) and some elbow grease. Also, it does not hurt to clean the clutch sheaves and rough them up with a green pad, before you put that new belt on.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I didn't know that. Could that be why me sled hits the rev limiter? I didn't do anything to the last belt I bought, but I had to change it while out on the trail. Is it too late to take it back off and do the cleaning procedure?
rightarm
Charged RTX said:I have been searching the forums and can't find the specs on these belts. Does anyone know where to find this info? I want to try a softer belt this season and am considering the XS 805. I think it is a little wider which I like but I do not know the length compared to the 8dn. I have also heard that there are a couple more XS belts that work.
Dayco Ultimax 3 part # 138-4432-U3 also check aliment
Len Todd
I suspect that you could take it off and clean it and the sheaves too.
Apex Man
Belts
XS805 is the one you are talking about.
rightarm
Len Todd said:SnowTech guys are also saying 8DN is too hard. They are recommending Dayco Ultimax 3 part number 138-4432-U3. They say it is softer and only slightly longer.
The dayco belt is thinner as well allowing to ride higher in the secondary.
Yamaholic22
rightarm said:Len Todd said:SnowTech guys are also saying 8DN is too hard. They are recommending Dayco Ultimax 3 part number 138-4432-U3. They say it is softer and only slightly longer.
A thinner belt will not ride higher in the secondary...a wider belt will ride higher in the seconday.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Wider and longer is better.
SharkAttak
i used the ultimax 3 on my viper a few years back it real soft, grabs great but didn't last as long as the 8dn, it would shred, is the xs805 different
