lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Boys,
I'm starting on a customer's CPR kit on an 07 Attack tonight. He's a life long skidoo guy and is having a little trouble letting go. I have to make this rig look as much like a doo as possible - he want everything to be yellow. I know, I know...
Anyway, I need to find some 136" yellow sliders. Anyone have a part number or a suggestion from the aftermarket crowd?
Thanks, Jim
Thanks, Jim
gilly67
i put ski-doo slides on mine they fit perfect, I would have to call the dealership for the part number but will have to be tomorrow cause they are closed on mondays
SharkAttak
gilly67 said:i put ski-doo slides on mine they fit perfect, I would have to call the dealership for the part number but will have to be tomorrow cause they are closed on mondays
yes, please post the # for the doo part on the hyfax, that is good to know in a jam
Tork
you know the sliders went wider with the 4 strokes
But I was in the middle of a hyfax change at the begining of last season and all I had were the narrower ones (pre 2003, used on everything).
So I put on the narrow ones, I like em better!!!!!! Lasting longer even.
So here are those in yellow
http://www.yamaha-motor.com/sport/acces ... etail.aspx
SharkAttak
i like the narrow ones too, less drag
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
The viper hyfax will fit, just a little narrower but work very well.
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
Thanks guys. It would be great if someone could post the doo part # tomorrow.
gilly67
just got the number part number for yellow ski-doo hyfax 503191089
Justin said they go on a little hard but they will fit just fine
Gilly
Gilly
timc
www.hiperfax.com . Not only can you get yellow, they won't melt until 750 degrees. Cost more but will outlast OEM 10times over!
TimC.
TimC.
- 7K
