RoicIND
So.....
I went through all of the old topics and stil haven't received an answer to this one..
Do you need a protector for the front heat exchanger? (1" lug, 1.075" studs)
I have some 1" square Aluminum tube that i was going to rivet in for the straight pieces, but was curious to see if i needed to bend up a few pieces for the front heat exchanger???
terret725
i dont think so. i just put a inch 1 3/4 track with studs on mine and they are sill over an inch away. the track is never going to strech enough to reach the front exchanger IMO. the only way the protectors would get hit would be if u had a 3 sided rip out, and at that point protectors arent goin to do anything anyway.
irace
- Sep 2, 2008
Rath Racing make the Yamaha tunnel prot. you might want to check with them as to cost. I've seen some major damage from running without prot. on other sleds
terret725
um isnt rath racing 4 wheeler racing products? ive never heard of them making anything for a sled?
nytro23
tunnel
I just riveted some half worn slides in my son's tunnel, just make sure to line them up with the track windows. Cheap, effective way to do it.
terret725 said:um isnt rath racing 4 wheeler racing products? ive never heard of them making anything for a sled?
I thought same.It awesome he is getting into sled stuff.He makes darn nice ATV products.
phazme
You dont need them in the front theres about 3in clearance I have an 07 with 1in track and 1.250 stud no problem in front but you neen them in the tunnel and in back for when the susp. compresses the studs will hit. they did on mine.
SRXTripman
Rath?
I went to Rathracing.com couldnt find anything for sleds what so ever if you have send us the link thanks .
terret725
we've been using rath for our quad race team at work. a arms, bumpers, etc.. rear bumpers havent realy been holding up to racing tho weve had every one welded about 4 times lol.
phazme
Just go to yamaha they cost a little but well worth it.There's no messen around easy to install. And a direct fit.
djpegg
I have an 07 Phazer FX and the guy I got it from did the back with a few 4 to 5 inch pieces of use slides. I want to install protection for the whole tunnel, but it seems I cant find them on Yamaha.com. Any links or help would be great. Thanks
Just use some old slides! Rivet them on and call it good.
