twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
The Stud Boy Super-Lite Pro scooped backers help a good amount. When I had my 180hp MPI turbo Viper with those installed, I raced a stock 17 Sidewinder LTX that had a 1.75 track on loose snow and pulled on him right from the get go. If the race has been longer, he may have cought up but it didn't happen in around 800'. I run them on my tuned Sidewinder now... although I haven't raced anyone from a dead stop yet.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Couple of things that can be done to set up for loose snow and no traction that may help depending on your power or tune..Run tight belt to sheave clearance in primary but not so tight it creeps .. 22 thousands or more.. Lower your primary clutch engagement using a set up design to do that… Lower it until you stop spinning…. On good traction days you raise it back up…. Drop your belt lower in your secondary which will be like taking off in second gear …. Change gear ratio to lower number…. If your running like 21-41 go to something like. 22-38. These are just a couple of adjustments that you can try without changing track …If your spinning, your not winning , if your sled go up , your competitors will be going forward ….. Lol
stgdz
- Mar 27, 2021
- Buffalo MN
The sled came with a torsional secondary. I have the roller helix and stock spring. Should I switch back?
Simplespeed
- Jan 8, 2022
Many types of clutches, belts, helix and combinations can effect low end hole shot .. Thats a easy switch so no harm in trying or testing it …
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I have a bucket of those used if anyone wants them. enough to do 144 studs, singles and doubles. @500 miles on them.The Stud Boy Super-Lite Pro scooped backers help a good amount. When I had my 180hp MPI turbo Viper with those installed, I raced a stock 17 Sidewinder LTX that had a 1.75 track on loose snow and pulled on him right from the get go. If the race has been longer, he may have cought up but it didn't happen in around 800'. I run them on my tuned Sidewinder now... although I haven't raced anyone from a dead stop yet.
I'd trade them for a 12 pack of beer.
stgdz
- Mar 27, 2021
- Buffalo MN
So an update, there was quite a few trails around central MN that turned into granite hard pack snow. Stuff was so hard.
Didn't have a problem with hookup there, but ran into a few loose snow conditions where it became squirrels.
So now on the lookout for a new track and some scratchers that won't fall apart like the straight line performance ones.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
BRP Ice Scratchers
My buddies have been running these tunnel BRP Ice Scratchers on their Poo and Doo's last year with great results and doesn't beat up the paint on the skid like the wire ice scratches seem to do.....at least for me. I thought if these work for Poo and Doo, they must work on Cat and Yamaha...
ty4stroke.com
stgdz
- Mar 27, 2021
- Buffalo MN
Tried those, couldn't find a good mount point where the upper wheel wouldn't contact it.
Probably going to use duraflex.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Got them on 3 sleds now. No issue with contact? Not sure where that could even happen with the correct length bolt. Tried them all. Best location for cooling and mounting out of the way.Tried those, couldn't find a good mount point where the upper wheel wouldn't contact it.
Turboflash
- Mar 18, 2019
- Southern MN
Duraflex carbide ends carve/churn up even ice.Tried those, couldn't find a good mount point where the upper wheel wouldn't contact it.
- 40K
