03 yamaha snowmobile rx1
Ryanjt86
Alberta
Canada
2003 yamaha rx1
I have had my sled for 3 years and it's wicked sick
But last year my sled will shut off after 2 min of riding "it's like I hit ghere kill switch .
I can start it up again after a few turn over and the same thing will happen it shuts off again.
Is it a fuel pump prob or sensor??
Can someone plz help me out thx
Sounds electrical. Lack of fuel would not be an instant shut down...it would bog and stutter for a bit for shutting off.
might want to post in rx1 area if you have not already also. I am not familiar with that problem as a known issue I would be checking wiring around kill switch and key area. also check resistance in stator it could be failing when warm.
moved it for you.
have you replaced the fuel filters and checked the wiring in the nose of the sled? is the vent for the tank plugged?
Apparently, ask a question and run...... Just started looking at the forum myself this year since it "looks" like we may be getting winter....... Lots of cold coming, just not enough snow to open the trails here in NW WI.....
