henseljg2
I'm working on an 05 rage for a buddy and this thing is running like crap. First it wouldnt run at all. Cleaned the carbs which were filthy. After cleaning the carbs, sled ran but running rough and popping every now and then. You can get on the throttle and the sled seems like it's got power. Sled shakes and almost sounds like its missing. Put fresh gas in, replaced plugs, then swapped out coils.
My next move is to start checking electrical connections, testing the stator and swapping out the ecu.
Any other suggestions?
