henseljg2
I'm working on an 05 rage for a buddy and this thing is running like crap. First it wouldnt run at all. Cleaned the carbs which were filthy. After cleaning the carbs, sled ran but running rough and popping every now and then. You can get on the throttle and the sled seems like it's got power. Sled shakes and almost sounds like its missing. Put fresh gas in, replaced plugs, then swapped out coils.
My next move is to start checking electrical connections, testing the stator and swapping out the ecu.
Any other suggestions?
theCATman
- Feb 19, 2007
- WI
- Yamaha
Carbs out of sync, or timing chain tensioner has failed, chain jumped time.
Both of which would result in a poor idle.
Latter if which will result in catastrophic engine damage.
Sent from my SM-G930R4 using Tapatalk
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Did you drill brass caps so you could remove air fuel screws and ensure idle circuit is clear?
Did you drain tank and dry 100%? Water settles to bottom and will be last to remain in tank. I use small rags to wick up last bits of fluid after siphoning.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
In addition to all the above mentioned, I'd say it's time to install new o-rings on all the jets and needle valves too; they dry rot and leak. If the gas tank is too cruddy inside, remove and power wash it out. Once dry, re-install the tank with a new fuel filter.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Don't just try to clean the pilots, install NEW ones.
henseljg2
Ok. Thanks everybody for the assistance. Looks like I've got some work to do.
The carbs were filthy. Almost every little hole was plugged in the Jets and pilots.
I suck at carburetors so I may just swap them out with a good set and see if there is any change in performance. Along with Draining the gas tank and starting from scratch.
X2, 99% of the time this is the problem.
Redbeard
- Oct 14, 2011
- IN
You should still sync the carbs, even if you swap racks. It's unbelievable how much it really does effect the way they idle.Ok. Thanks everybody for the assistance. Looks like I've got some work to do.
henseljg2
I've never synced carbs before. I'll have to study up on that. I converted to Yamaha and went straight to fuel injection.
henseljg2
Sweet. Thanks for the info.
Redbeard
- Oct 14, 2011
- IN
http://www.ty4stroke.com/threads/carb-sync-tool.108472/
Here is another link for a home made sync tool...pretty cool!
Again, sync after all the above mentioned items have been cleaned or replaced!
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Personally I would take the carbs off and take them to a shop that can "sonic clean" the carbs. It's a somewhat special process. Have them install new pilots when they put them back together.
Synching the carbs is important and Grizztrack's homemade synch tool is awesome. BUT, I've never seen carbs so out of synch that they'd do what you are describing. As Mr. .Sled suggested, this sound slike a plugged pilot issue.
henseljg2
Ok. She's back to 100%. Definitely a carbit issue. I believe based on the amount of gunk, these carbs had no hope of clearing out just pulling the bowls and cleaning at an amateur level. I think that explains the poor idle but I also believe they were out of sync due to the popping and shaking.
I swapped in a good set and she's finally back to normal.
Anyway, thanks to everyone for all the info and help.
