WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Ryanmlt1 had the exact same sound, I changed the belt and it was gone,
Do you have another belt to see if the noise is still there? If not loosen the belt (yes washers),
Ryanmlt1
No I don't have another belt. I will remove the washers. If it comes back I will just get a new belt and start from there.
Thank you everyone! I overreacted a little. Its my new baby and I really don't know her history. So when a strange noise appears on my first ride I got concerned.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Ryanmlt1 - A New belt will squeal more than a used belt. And it's normal on the 4 strokes.
Want to fix it, here's how to:
- Take the belt off
- Remove the secondary
- Remove the 3 small bolts at the inside of the secondary
- Remove the washers
- Install the 3 bolts and secondary
- store the washers you will need them when the belt wear Down
With the washers removed the belt will ride lower in the secondary making it ride a tiny bit higher in the primary and the squeal is gone. As I said![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- Take the belt off
stevieu1
Had the same problem. I put on a new belt and it squealed.just take the washers out, that IS the adjustment.you will be fine. You are hearing it in the primary because that is where it's rubbing. ![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
As long as it does not take off and leave you don't worry about it but yes djusting the secondary will fix it.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
X2 what Icebreaker says... deffinatley cluth-belt squeal. Did you put a new belt on? If you have a old belt change an see if the noise goes away.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Normal! Belt is a touch tight. On my RX I had one that squealed until the day I replaced it. That was also the fastest belt of them all.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Sasquatch - a slightly Shorter belt results in higher top speed as long as you run an aftermarket helix cut for overdrive, clutch ratio With Stock helix is 0.97:1 With a cut helix it's 0.93:1
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
Usually after a new belt has been installed if you dont adjust the height of the belt in the secondary it will squeal like that. I just ignore it and it goes away after some riding.
- 147K
- 33K
