WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Ryanmlt1 had the exact same sound, I changed the belt and it was gone,
Do you have another belt to see if the noise is still there? If not loosen the belt (yes washers),
Ryanmlt1
No I don't have another belt. I will remove the washers. If it comes back I will just get a new belt and start from there.
Thank you everyone! I overreacted a little. Its my new baby and I really don't know her history. So when a strange noise appears on my first ride I got concerned.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Ryanmlt1 - A New belt will squeal more than a used belt. And it's normal on the 4 strokes.
Want to fix it, here's how to:
- Take the belt off
- Remove the secondary
- Remove the 3 small bolts at the inside of the secondary
- Remove the washers
- Install the 3 bolts and secondary
- store the washers you will need them when the belt wear Down
With the washers removed the belt will ride lower in the secondary making it ride a tiny bit higher in the primary and the squeal is gone. As I said
- Take the belt off
stevieu1
Had the same problem. I put on a new belt and it squealed.just take the washers out, that IS the adjustment.you will be fine. You are hearing it in the primary because that is where it's rubbing.
As long as it does not take off and leave you don't worry about it but yes djusting the secondary will fix it.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
X2 what Icebreaker says... deffinatley cluth-belt squeal. Did you put a new belt on? If you have a old belt change an see if the noise goes away.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Normal! Belt is a touch tight. On my RX I had one that squealed until the day I replaced it. That was also the fastest belt of them all.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Sasquatch - a slightly Shorter belt results in higher top speed as long as you run an aftermarket helix cut for overdrive, clutch ratio With Stock helix is 0.97:1 With a cut helix it's 0.93:1
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
Usually after a new belt has been installed if you dont adjust the height of the belt in the secondary it will squeal like that. I just ignore it and it goes away after some riding.
