'06 oil light on but oil level is fine
ZR800EFI
Morewood, Ontario
Riding in the Gaspe last week, my oil light came on a few times after I started the sled. It was after we were running fairly hard for a bit (constant 60-80MPH), then we'd stop for a few mins, fire it back up and the light would come on.
The first time, I turned it off to check the level and it was 3/4 the way to the top. Put it back together, ride down the trail for a minute and it would go off.
We tried changing the dipstick/sensor from my buddies, but mine still had the problem.
Anyone ever see that before? No error codes being thrown for low oil pressure or anything...
DO NOT thread in the dip stick when checking the oil level. If you do then it will appear that you have plenty of oil when actually you are close to being low when it is checked properly.
Checking the oil per the 2003 RX-1 Service Manual:
Click thumbnail for larger image
No, I'm not threading in the dipstick...just set it on top after cleaning it off. I've got almost 12000 miles on the sled and this is the first time it's happened.
That sensor is activated by heat when the oil is low the entire tank is warmer and it triggers the light. Have you checked for proper circulation? with teh sled running peak in the opening and look for oil swirling around. If its full then check the resistance of the sensor with a multimeter make sure its got contivity.
It's not heat activated...otherwise it wouldn't come on when the engine is cold and the level is down (which it does).
Check the wiring that goes to the plug...maybe there's a rub through or a broken wire. I have seen the sensor fail before but you mentioned you tried your buddy's...
Can you see recirculation in the tank with it running. maxdlx
I will have to check...I won't be able to until tomorrow. But the light does go off after I ride for a minute...does that mean anything for this?
the oil light is level only. if you have verified there is the proper amount of oil you can drive the machine. the dipstick works off of electrical resistance. the fluid creates a ground. simplely asking did you top off the fluid. you siad it was almost full, why not try it filled.
I will top it up...it was the last day in the Gaspe and I obviously wasn't carrying oil (part of the reason for buying a 4-stroke). I will top it up and see how it is after.
Thanks.
a friend of mine did the same thing turned out being bad dipstick sensor.
try exchanging one from another sled, if possible. i think he said they were about 60 bucks.
