RC Apex
- Jan 21, 2020
- Chardon,Ohio
- 2007 yamaha apex gt
I have an o7 apex gt what are some good suggeted upgrades?
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Get the 13mm sway bar from BOP and different skis.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
The list depends on how much you want to spend, how you want the sled to perform, and whether or not the mods will be done by you or by someone else.
And the current condition and mods of the sled.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
How many miles?
Some things aren't "upgrades" but rather necessary maintenance procedures or there will be no enjoying of "upgrades"
RC Apex
- Jan 21, 2020
- Chardon,Ohio
Sled has less than 3000 miles and all stock im an adrenaline junkie and dont like to go slow and am not afraid to push the sled
RC Apex
- Jan 21, 2020
- Chardon,Ohio
Definitely need better hook up off line....
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
Rebuild and most importantly revalve the rear shock.
Front shocks, go 2-3 clocks out from full hard on compression. This will help it corner much flatter. Depending on your riding style you might want more front end bite. I used shaper bars, a lot like snow trackers but I have not tried them.
I found with some setup this was a much improved machine.
Go to a 23 tooth to gear. They say that helps a lot on the GT.
If you want speed....supercharge or nitrous.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
3000 miles is not that high so you don't need to go "replacement crazy".
Next year you'll need front end bushings & donuts, but let's concentrate on what you want to do to this thing.
How fast do you want to go & how much $ do you want to spend?
There are not many cheap BIG gains.
You can gain a few ponies here & there, but by the time they get to the track, it's minor.
Turbos & Superchargers are expensive & add weight.
Nitrous is simple, but made mostly for racing.
There is a little charger out there called G-Force for around $2000 that gives 2lbs of boost for about 20 hp.
I think you should improve traction & handling this year THEN next year change things up.
It's still a fast sled that can hang with anything out there.
I have/had the exact same sled.
It's my buds' now with 22,000 miles on it.
SnoTrackers, rebuild & calibrate all 3 shocks then set it up properly.
Check & repack all bearings & change the driveshaft bearing under the secondary clutch.
After you ride it, come back here to tell us what you'd like to do cuz we have JILLIONS of miles on these things..............and JILLIONS of opinions also. LOL
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
HID lights & hand warmers, both from ROCZ TOYZ!
Start there
Start there
RC Apex
- Jan 21, 2020
- Chardon,Ohio
I live in north eastern ohio so only get a few rides a season unless i travel which im not afraid to do me and a friend are looking for some good places to travel to and ride as long as it isnt like a million miles away.. ive ridden dirtbikes,quads and sleds most of my life i have broken many things on me and bikes so im not afraid to push it.
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
Where at in NE Ohio? That's where I'm located.
Take two teeth off the speedo pickup so your speedo doesn't lie to you, and you will rack up less miles.
RC Apex
- Jan 21, 2020
- Chardon,Ohio
Chardon oh.. you?Where at in NE Ohio? That's where I'm located.
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
Oh man you guys in Chardon get all the Ohio snow.Chardon oh.. you?
I live in Niles but work in Middlefield. Right down the road from ya.
The only real trails in NE Ohio is the Greenway bike trail area. And over closer to the PA border there are the Stateline Snotracker club trails. That's about it for us.
RC Apex
- Jan 21, 2020
- Chardon,Ohio
We do get snow but gotta find places to ride i hear thompson has a club i gotta look into that... i work at junction auto familyOh man you guys in Chardon get all the Ohio snow.
