vx700xtc
Relay is clicking, but still no fuel pump. Where do I go next?
jagabom
Make sure it is the relay you are hearing. Try changing it out with another. There should be a fuel pump fuse somewhere, maybe by the starter relay.
Jim
08 APEX
Jim
08 APEX
duste
- Nov 25, 2008
- New Glasgow, N.S. Canada
- 2007 Attak
Check the grounding plugs inside the main harness, under the airbox by the drive clutch. They corrode and cause multitudes of problems and the older the sled gets the more common it's becoming. Just checked mine and greased it to prevent this from happening.
vx700xtc
mice had chewed wires off of fuel pump.
duste
- Nov 25, 2008
- 2007 Attak
Well that won't drive you crazy looking for a problem. Glad she's fixed.
apex55
Every year the little buggers build a nest right on top of mine. They chewed up the plastic clip that hold the fuel line this year.vx700xtc said:mice had chewed wires off of fuel pump.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Not 1 mice issue in the past 15+ years with the sled stored in an enclosed trailer.
