Antewallgren
- Nov 23, 2019
- Sävar
- Sweden
- Yamaha Phazer FX 07
Okay, I read something about the bearing of one of the reduction gears was spinning in the outer layer, whcih grinded out aluminium from the engine housing.Remove the primary clutch and then remove the cover behind the primary clutch to access and have a visual of the gears. Since it didn't fail completely like the one I fixed, you should be able to fix everything without engine removal.
Antewallgren
- Nov 23, 2019
- Sävar
- Sweden
Did you buy the machine new?
Nope! I bought it three weeks ago. I didnt have a clue about this whining sound, until I searched for it...
CCCT
- Jan 9, 2017
- Barrie/Sudbury/Muskoka
- 2007 Apex
2009 PhazerGT
Pretty sure my 09 gt with 4000kms makes the same sound idling as in the vid. Are we saying this is baad? I thought it was normal. Eek.
Only 07's were known to have this issue.Pretty sure my 09 gt with 4000kms makes the same sound idling as in the vid. Are we saying this is baad? I thought it was normal. Eek.
I am not aware of that.Okay, I read something about the bearing of one of the reduction gears was spinning in the outer layer, whcih grinded out aluminium from the engine housing.
This issue was faulty reduction gears and there was a bulletin way back in 07-08
CCCT
- Jan 9, 2017
- 2007 Apex
2009 PhazerGT
That's what I thought too. I'll record a vid of mine next week to make sure I'm not imagining things.
Antewallgren
- Nov 23, 2019
- Sävar
- Sweden
Read the first post of this thread: https://ty4stroke.com/threads/07-mtx-reduction-gear-bearing-ok-engine-case-is-a-goner.100647/I am not aware of that.
What was the problem with the gears? Poor mating?
Does anyone have the chassienumber interval of the sleds that have this issue?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
All I hear is a slight whine when it's revved up a bit which sounds normal to me. And at 6000km, it would have blown up by now. The reduction gears on these blew up fairly early in their life at low KM, like the OP's did.
Mooseman may be right.
Again, I've always found noise in videos like this to be slightly different than if the machine was right beside me.
Could be normal but if it was mine, I would remove the side cover and visually inspect.
There was an affected VIN range as indicated by Yamaha, so you could check that also.
I agree with Mooseman. Run it. Mine make the same light whirring noise and has 20000mi on it. If really bothering you just pull the stubshaft and gear. The ones I saw the gear was actually burnt from being too tight.
