lukebackstrand
My 07 phazer cranked over slow last week, I stopped for about 2 hours and went back to start it and it cranked slow till the battery was dead. I tried to jump it and cranked slowly then a puff of smoke came out of engine department and it smelled electrical. Now when I try to start it power only goes to the relay. I have recharged battery. I'm not sure where the starter is located. Any ideas...
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Did you have the bolts on the starter locktited?
http://www.ty4stroke.com/viewtopic.php?t=64045
The electrical smell does not sound good, how long where you cranking it over for?
lukebackstrand
I've never had it off so I'm not sure
- Nov 1, 2009
- 2009 Phazer RTX
Then they probably backed out and the starter came out of alignment. It was a problem with the 07's the fix is to follow the steps in that link i posted.
Not sure about the smoke you might have burnt something if you where turning it over too long.
lukebackstrand
could you post the link again it didnt show up
- Nov 1, 2009
- 2009 Phazer RTX
- 11K
