Won't start...cranks, pump runs, spark at plugs, no error codes??
hibshman25
Vendor
Lebanon, PA 17042
2017 sidewinder ltx dx
2018 snoscoot
Swapped a few parts around on a 2011 nytro this morning and it won't start.
Fuel pump is running. Got pressure in line when I take it off the pump.
Got spark on plugs when cranking. Plugs are bone dry...not wet and fouled.
Starts up if I spray starting fluid in air box.
Seems to me the t bodies are not injecting any fuel. Any one else ever have this happen?
How about the overflow vent line? Is it pinched?
What did you swap around?
Travis I'm assuming your not getting codes on the display. Check the main fuel injection fuse. Here is a pic #10 is fuse #7 is the battery. Good luck
Pete
Left it sit and 1/2 hour later it fired right up. Chris at Schmidt brothers thinks the injectors were plugged by a film from sitting with no fuel in them. I had pulled the trail tank off several months ago.
That's great Travis. Run some Seafoam thru the gas tank and that should finish cleaning up the injection system.
Pete
Be careful with starting fluid! It is very dry and almost acts like a cleaner. It will take the oil off of your cylinder walls if you use too much, I prefer to use a squirt can of gas for this process.
