- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Yea I should have made it more clear. I ment the chain. Then asked how to adjust the belt but then decided I should do a search.
Thanks.
Thanks.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
marpolsdofer said:08 with GS belt, no shims, set at 1/8 above (hair more)= no reverse with out Fin it. + side- no engine braking and if ther is barly noticable, smother shift and very quick, lot better top end on deep snow.
I wonder if having the belt adjusted higher makes it tighter and binds the driveline when you're trying to shift in reverse. Or it's putting more torque even when idling. This could be the equivalent to shifting in reverse while at higher RPM.
Ruckus
marpolsdofer said:you have to remove the side covers. Mine is set for preformance only. I have looked over this led with everyangle in thepast 2 months to get it readyto race in a limited budget. 08 with GS belt, no shims, set at 1/8 above (hair more)= no reverse with out Fin it. + side- no engine braking and if ther is barly noticable, smother shift and very quick, lot better top end on deep snow.
This is what it feels like when I ride it, http://www.youtube.com/watch?v=DKRqXiPIYi0
Are you from from Sweden?
marpolsdofer
No, I was was looking for the vidoes of there indoor snowmobile trail park. The only video I could find was this and the phazer fx indoor tunnel ride. I would like to snowmobile there, they have some good snocross racing to.
Anyway, I am leaving for Grafton.
RedPhazer
marpolsdofer said:Whilethesled is runnin, need reverse, and can not get it to engier by rocking or jumping. I will rotate the secondary by hand to take presseur of the reverse gear. Let it go and it will engage.BombaPolaYama said:marpolsdofer said:Your belt has to be at least level to git it to work. I put my belt 1/8" and lost reverese; so if I want to use it I have to moe the secondry by hand.
move the secondary by hand?? please explain?
I know I'm a wuss... but that sounds a little dangerous while the sled is running!
marpolsdofer
Yes it can be dangerous! If your just traile riding dont do it. I just do it becaues I never really need reverse.
I grab it form the top side, but if I dont feel like taking of the clutch cover off I will use the side of the clutch and grad the braces. Just stay away from the primary.
shredder
I am interested in what you have to say, but it would help if your post was legible...marpolsdofer said:you have to remove the side covers. Mine is set for preformance only. I have looked over this led with everyangle in thepast 2 months to get it readyto race in a limited budget. 08 with GS belt, no shims, set at 1/8 above (hair more)= no reverse with out Fin it. + side- no engine braking and if ther is barly noticable, smother shift and very quick, lot better top end on deep snow.
BombaPolaYama
RedPhazer said:marpolsdofer said:Whilethesled is runnin, need reverse, and can not get it to engier by rocking or jumping. I will rotate the secondary by hand to take presseur of the reverse gear. Let it go and it will engage.BombaPolaYama said:marpolsdofer said:Your belt has to be at least level to git it to work. I put my belt 1/8" and lost reverese; so if I want to use it I have to moe the secondry by hand.
Yeah, that's what I was thinking! surprised someone would even sugggest that manoeuver!
BombaPolaYama
shredder said:I am interested in what you have to say, but it would help if your post was legible...marpolsdofer said:you have to remove the side covers. Mine is set for preformance only. I have looked over this led with everyangle in thepast 2 months to get it readyto race in a limited budget. 08 with GS belt, no shims, set at 1/8 above (hair more)= no reverse with out Fin it. + side- no engine braking and if ther is barly noticable, smother shift and very quick, lot better top end on deep snow.
That point has been made about 3X but apparently he doesn't care to make his posts easily readable....just very difficult and time consuming to try and decipher.
- 9K
