2stroken
I was doing some searches, and curious if any new reverse issues. I think it boils down to I have the wrong belt, as I blew a belt a few years back and since then reverse has been a struggle. Should I do a new belt, or do the shim? What is the updated belt number?
Struggle? Can you be more specific?
Kevin0311
- Mar 14, 2022
- NY
- 2007 Phazer FX
once in a while depending on position of sled i have to rock mine to get it to "click" in otherwise works fine.
2stroken
LOL, yea I guess that would help. Basically it doesn't go in to reverse unless I get off of the sled and pull it backwards. I have 2 other sleds and they go into reverse perfectly(08 phazer, 07 venture lite). Idle is around 1600ish, have loosened the chain tensioner. As I mentioned it worked well until I blew the belt, when I say blew the belt, it just shredded the belt, and just put the belt on that came with the sled. I am thinking there was a belt number change that helped.(I suspect this one is slightly shorter, or slightly wider and dragging on the secondary)Struggle? Can you be more specific?
Yes, I would try the belt first. Sorry I do not know the belt numbers off the top of my head. I can check with some manual and see if spec has changed,LOL, yea I guess that would help. Basically it doesn't go in to reverse unless I get off of the sled and pull it backwards. I have 2 other sleds and they go into reverse perfectly(08 phazer, 07 venture lite). Idle is around 1600ish, have loosened the chain tensioner. As I mentioned it worked well until I blew the belt, when I say blew the belt, it just shredded the belt, and just put the belt on that came with the sled. I am thinking there was a belt number change that helped.(I suspect this one is slightly shorter, or slightly wider and dragging on the secondary)
Kevin0311
- Mar 14, 2022
- NY
- 2007 Phazer FX
Clutches backing off all the way, no belt debri stuck in there?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
