satan660
ok i have 03RX-1 with bender stage 2 rear mount turbo... i posted some pics of my tunnel running 1"1/4 ripsaw with 1.375 studs...the studs ate right through the tunnel, what size track and studs are you guys running thanks... or what can i do to fix this!!!!!
Moose Magnet
Hey dude, I have a 1" track for sale real cheap. That will solve your problem.
rerod
Good god, tighten your track man.
satan660
do you think thats all it is.....rerod said:Good god, tighten your track man.
sledheadgeorge
Tighten your track, add 1/4" to your tunnel protectors, don't go over 100mph very often, or ............get a 1" track.
Ted Jannetty
satan660 said:do you think thats all it is.....rerod said:Good god, tighten your track man.
That and your getting on the brakes too hard.
you could add some tunnel protectors also.
Take some slides, cut the lips off so you have 1/4" thick plastic, counter sink holes every 6 inches on the top or long ones and every 1 1/2 inches on the front ones, and rivet them to you existing protectors.
satan660
the front ones too
ted should i do the front tunnel protector or just the top thanksTed Jannetty said:satan660 said:do you think thats all it is.....rerod said:Good god, tighten your track man.
satan660
Re: the front ones too
sorry 1"1/2 on the frountsatan660 said:ted should i do the front tunnel protector or just the top thanksTed Jannetty said:satan660 said:do you think thats all it is.....rerod said:Good god, tighten your track man.
