1"1/4 ripsaw with studs eating my tunnel
satan660
barber's bay ont
ok i have 03RX-1 with bender stage 2 rear mount turbo... i posted some pics of my tunnel running 1"1/4 ripsaw with 1.375 studs...the studs ate right through the tunnel, what size track and studs are you guys running thanks... or what can i do to fix this!!!!!
Tighten your track, add 1/4" to your tunnel protectors, don't go over 100mph very often, or ............get a 1" track.
satan660 said:
rerod said:
Good god, tighten your track man.
do you think thats all it is..... ;)!
That and your getting on the brakes too hard.
you could add some tunnel protectors also.
Take some slides, cut the lips off so you have 1/4" thick plastic, counter sink holes every 6 inches on the top or long ones and every 1 1/2 inches on the front ones, and rivet them to you existing protectors.
the front ones too
ted should i do the front tunnel protector or just the top thanks
Re: the front ones too
sorry 1"1/2 on the frount :o|
