satan660
ok i have 03RX-1 with bender stage 2 rear mount turbo... i posted some pics of my tunnel running 1"1/4 ripsaw with 1.375 studs...the studs ate right through the tunnel, what size track and studs are you guys running thanks... or what can i do to fix this!!!!!
Moose Magnet
Hey dude, I have a 1" track for sale real cheap. That will solve your problem.
rerod
Good god, tighten your track man.
satan660
do you think thats all it is.....rerod said:Good god, tighten your track man.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Tighten your track, add 1/4" to your tunnel protectors, don't go over 100mph very often, or ............get a 1" track.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
satan660 said:do you think thats all it is.....rerod said:Good god, tighten your track man.![]()
That and your getting on the brakes too hard.
you could add some tunnel protectors also.
Take some slides, cut the lips off so you have 1/4" thick plastic, counter sink holes every 6 inches on the top or long ones and every 1 1/2 inches on the front ones, and rivet them to you existing protectors.
satan660
the front ones too
ted should i do the front tunnel protector or just the top thanksTed Jannetty said:satan660 said:do you think thats all it is.....rerod said:Good god, tighten your track man.![]()
satan660
Re: the front ones too
sorry 1"1/2 on the frountsatan660 said:ted should i do the front tunnel protector or just the top thanksTed Jannetty said:satan660 said:do you think thats all it is.....rerod said:Good god, tighten your track man.![]()
