ess
- Mar 9, 2006
- Western NY
- ericssalesservice.com
Looks like I got the bad apple this year (2011 SE), best I can get on GPS is 97mph. Ran it for about 1/4 mile in the best trail condition so far. Have about 1500 miles now, RPMs at 10,400. Only added 153 studs to the track. All else stock. Have notice about a 1/2 inch of area on outer edge of my primary clutch which the belt has not shifted out to. Is that normal? My 06 GT GPSed at 109 and I was expecting this '11 to be slightly better... damn! Any suggestions would be helpfull, thanks.
Forgot, I did add marginal snow wheels to the front rails and added stiffener brackets to the tunnel protectors.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Maybe your fix will be in here http://www.ty4stroke.com/viewtopic.php?t=98270
Turk
Tech Advisor
Try different premium fuel. The knock sensor is very sensitive & kicks the crap out of the performance when you get mediocre gas.
ecopter
I'm right at that 10400 number as well. Sometimes I may hit 10500. I haven't had a chance to wind it out, however. I've had it up to 105 mph on the speedo which averages out to around 102 mph. I need a longer area to stretch its legs, but, I'm still only getting 10400.
jf
jf
RollRite
- Dec 16, 2004
- Pickerel , Wisconsin
- 2011 Apex
I'm in the same boat my dealer is going to take 1gram out of the tip of my weights tomorrow Then I will see what happens.
yamahahaapex
what are you running right now roll right? RPMs and top end
RollRite
- Dec 16, 2004
- 2011 Apex
I'm at 10,000 and top out at 10,400
quebec#1
Not much more hp vs a 2010 and 30 + pounds more difference along with a longer track vs the 121 .
153 studs /snow conditions and 97 mph sounds right on to me !
yamahahaapex
0 degrees celcuis and no studs, I can just squeeze 112mph. hardpack wfo with no wind i cant say trails have been way to rough to go that fast again. i got lucky that day, a colder day and i shouldnt have a problem getting that again and maybe a bit more
yamahahaapex
the difference here is how fast these sleds are getting to top speed and staying there hence the wide power band
RollRite
- Dec 16, 2004
- 2011 Apex
Well today my dealer took the rivit out of tip from weights and man what a different sled I hit 10,800rpms in 1,500 feet and hit 109 mph I had a hard time hitting 103 mph in a mile befor
ecopter
pm'd you RollRite.
Did your dealer take the whole rivet out and leave the tip empty?
jf
jf
RollRite
- Dec 16, 2004
- 2011 Apex
Yes he did there was a 2 gram rivit in the tip
ecopter
Wow, did that make a difference. Zipped up to 110 and had to back down as I was out of room. Had more to give as well. Should have done this a long time ago.
Thanks,
Jon
Thanks,
Jon
RollRite
- Dec 16, 2004
- 2011 Apex
Ecopter
You like it now.
You like it now.
