mopar yam
- Nov 10, 2011
Hi guys , what should my viper turn for rpms wot , it has a air box modd and 14.5 rollers with schmitt bros low engagement spring, the highest on good hard backroad is 8800 rpms should it be higher or am I right on ?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
sounds good to meHi guys , what should my viper turn for rpms wot , it has a air box modd and 14.5 rollers with schmitt bros low engagement spring, the highest on good hard backroad is 8800 rpms should it be higher or am I right on ?
mopar yam
- Nov 10, 2011
Wasn't quite sure ,I see some guys on here are saying they are around 9100 so I didn't know if I it was low cause it never hits the rev limiter which is ok I take it.
What speed are you getting in those conditions?
benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
Are you running stock weights?
mopar yam
- Nov 10, 2011
Yes stock weights, and Saturday we went down on the lake and plowed off a 1/4 mile strip and was shocked it ran 104 mph on the radar gun. Clean the clutches really good again and would rev too 9050 and come back down to 8800 wot. Plus I ran the track at 50 mm loose with 20 pound weight in the centre. Brother in laws new 850 ski doo ran 114 mph and my 2011 apex se ran 110 mph all stock. Don't think Ill try to improve the clutching cause what will I gain?
Right on! Nice speeds
- 33K
