I've done a couple 16 vipers with bearing failure.
I highly recommend going with winder setup.
FYI, to all 14-16 Viper owners, if u ever hear a strange noise coming from chaincase area, stop driving.
If u damage the inner case it adds a lot more expense.
GBoul
- Jan 7, 2023
- Quebec city
- Sr Viper RTX 2014
My wobble bearing 2014 have 21354km and is top shape,but my top gear bushing is shot,I install prevost performance top gear bushing and change all bearing in same time
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I am currently working on a 2014 ZR7000 that needs a complete chain case. The customer wants to upgrade to the newer style top bearing. If I were to get a complete case from a 2017 and up, then I would also need the upper shaft?
GBoul
- Jan 7, 2023
- Quebec city
- Sr Viper RTX 2014
Yes you need the complete jackshaftI am currently working on a 2014 ZR7000 that needs a complete chain case. The customer wants to upgrade to the newer style top bearing. If I were to get a complete case from a 2017 and up, then I would also need the upper shaft?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Thanks. Finding a complete case is proving harder than I thought.
GBoul
- Jan 7, 2023
- Quebec city
- Sr Viper RTX 2014
Pièce usagée pour VTT, Motoneige, Côte à côte | Mic Parts
Leader dans la vente de pièces usagées pour VTT, Motoneige et Côte à côte au Canada & États-Unis | Livraison en 2 à 4 jours
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I will call Monday. I would like to find a complete case, guts and all.
I have an email to BOP also, I like to support site sponsors when possible.
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
Could the 17+ shaft come from a CAT 9000? I know the secondary clutch is different, but not sure about the splines and shaft.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I am not 100% sure. I hope it the same splines, it would make life easier.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
It seems like the clutch splines are different For Cat 17 and up.
I am going to use the stock shaft and 62206 bearing and spacers to engage the clip.
smitty_j25
- Feb 2, 2015
- Nova Scotia
- 2014 SR Viper XTX
Would using the 62206 bearing eliminate the need for a spacer using the 17 shaft in a 14 chaincase?
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- Columbus, Indiana
I upgraded my ‘15 to the 17 shaft setup about 2k miles ago. I was originally planning to do the same as you’re talking about using a 62206 bearing. In the end, I just used the CAT 6206 instead and found a couple of 2mm thick snap rings that worked perfect for the spacers.Would using the 62206 bearing eliminate the need for a spacer using the 17 shaft in a 14 chaincase?
I see no reason the wider bearing wouldn’t work though.
smitty_j25
- Feb 2, 2015
- Nova Scotia
- 2014 SR Viper XTX
I got everything back in place and I don't think the wider bearing will work, there is no room to place the washer and circlip that hold the bearing from sliding on the shaft, I'm probably going to have to pull my bearing now and track down the spacers and circlips
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
When I installed a Sidewinder jackshaft in my 2015 Viper, I use the Sidewinder bearing in the chaincase and used 2 circlips as spacers. I used the 6206 bearing in the chaincase that the Sidewinder uses but needed 4mm worth of spacer. The circlips in the link below are 2mm thick so 2 of them gave me the thickness that I needed to make up. McMaster-Carr #98455A384I got everything back in place and I don't think the wider bearing will work, there is no room to place the washer and circlip that hold the bearing from sliding on the shaft, I'm probably going to have to pull my bearing now and track down the spacers and circlips
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
smitty_j25
- Feb 2, 2015
- Nova Scotia
- 2014 SR Viper XTX
I'll try to find something similar here, I also need to double check the clips and washers on the shaft and make sure I have all the right ones, I previously thought that I did but today when I had a chance to work on the sled realized I was mistaken
