Hopefully just wire. Otherwise you know where to get them.Gee Steve, and I thought I had it bad after last weeks/weekend riding. Apparently the solenoid in my EC shock on the 08 went out as no dash icon.
Ugh!ouch! just had to grab my brothers spare primary for my 11 as my spare was hit and the clutch on the sled i needed a rubber mallet to get the sliding sheve to move with the clutch empty.
I sure am leaning to magnets at least causing the shrapnel pits. Found some parts of them on skid plate bolt in tunnel
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Now the bad news. I ran it very hard on way back from Twin Lakes when I got separated from buddies. At one point after only getting 85mph pinned for at least 2-3mi I noticed lot of clutch noise and squealing belt. I think but cannot ever know for sure what happened first but I am missing magnets in wieghts. That’s all that’s missing but both clutches are pretty much Fubar! Will do all over using all Thunder Products. No more magnets for me!
View attachment 158420 View attachment 158421
What caused your spider to turn?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The longer I look at it i see what happened there. Bushings wore out then weights hit the spider and took magnets out.
RobX-1
- Coldwater, OH
I was wondering the same. Although I'm not that familiar with the clutches on the Yamacats, aren't there suppose to be a plastic bushing on both sides of the spider arms?
that is the same clutch as a nitro/apex. yup the sliders are toast on it. depends how deep the shrapnel pits are if it is salvageable.
Guys I went through these clutches this fall. The sliders were tight yet. Not sure what happened first.
You guys see the rollers in secondary! Crazy thing is the belt is still fine.
looks like some debris from the primary got into those rollers and jammed them. bet the belt threw the debris everywhere under the hood. if the vipers take their air in a place close to where the winders do, i would check inside the air box just to be safe.
More pics.
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
Yikes,save your lunch money,thats going to cost you some green backs.
Stimulus. GoneYikes,save your lunch money,thats going to cost you some green backs.
