newtayami
Gents
Have they changed the rollers in both clutches for 2019?
Are new HD rollers needed in driven for 19s?
What was the stock helix angle in 18 for a Sidewinder 137?
Has it been confirmed 2019 is changed for a reverse cut helix?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Stock helix in 17 and 18 models was a 35 degree.
The SRX comes stock with a 35/39 reverse angle but I can't confirm what the other models come with.
The driven spring in the SRX has been changed to pink again I can't confirm the other models.
I've ran cat rollers since 2017. I can't recall if the rollers were an issue on the 2018s. Someone will chime in.
Pstn head
I'v experienced wear on the updated 17 secondary clutch rollers over 6000km of use. I'm not sure if the updated 17/18 rollers are the same as the 19 rollers in the secondary clutch.
WinterWolf
- Mar 25, 2017
- Connecticut
In the 18’s, the rollers were the same as the 17’s. I changed mine to heavy duty rollers from TD from day one.
DMCTurbo
- Nov 12, 2005
I'v experienced wear on the updated 17 rollers over 6000km of use.
I still have the updated rollers in my toolbox. The cat torlons still look great after 6000kms.
Pstn head
Ya I'm going back to cat torlons.I still have the updated rollers in my toolbox. The cat torlons still look great after 6000kms.
Mototown
The 19 s rollers at show looked the same as the 18 updated ones
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The cat torlon rollers show wear on the inside where they ride on the pin. Just replaced mine last week.
DMCTurbo
- Nov 12, 2005
I'll have to check that out. Thanks.The cat torlon rollers show wear on the inside where they ride on the pin. Just replaced mine last week.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
You still liking that 41/35 helix for trail riding or did you find a better one?
DMCTurbo
- Nov 12, 2005
I'm very happy with the 41-35. I did a lot of testing with my TD GPS and its a lot quicker A-B than other helixes I tested. Now obviously I don't have a huge inventory of helixes but of the 4 I have it is the best for what I'm trying to achieve.
newtayami
So just install the HD rollers off the bat?
newtayami
Not looking for your recipe but curious to know what tune you are running this helix?’
Max Spool 17?
DMCTurbo
- Nov 12, 2005
Powertrail and Max17. I'm upgrading to Maxspool17 this year.Not looking for your recipe but curious to know what tune you are running this helix?’
Max Spool 17?
@123
are you going to test 41/37? that will be interesting!Powertrail and Max17. I'm upgrading to Maxspool17 this year.
- 15K
- 8K
- 9K
