WarriorWithin
Hey guys im thinking about putting a 2 gallon rotopax can on the back of my nytro and couldnt find any info or pics or anyone actually mounting one to the back of there xtx. Anyone have any info? Seen a few 1.75 packs on nytros which look great but hoping I can use the slightly larger one.
grumpysanta
why not a 3.5 tour buddy
WarriorWithin
I thought about a tourbuddy but was looking for something I can take off if I get stuck or if someone else needs fuel. Plus I should be able to get away with using a small piece of pipe to direct my exhaust up and back instead of a turnout.
grumpysanta
you don't need a turnout with the buddy and it empties first so the weight comes off first...and i carry a siphon hose with a one way valve for mty buddies
Nytro77
I'v seen rotopax on the MTX I think they look tidy and I thought of putting one on my xtx too however you wll have to relocate your rear tail light and get a turn out, it will be tight but should work. Tour buddys are great too and do the trick but I personaly think they look ugly.
grumpysanta
yes not the best looking but most others like roto and koplins dont look much better even yamaha cans in a bag stick out too far, with the roto or koplins you need another mount to put on the sides . rear mounts have to move tailight
grumpysanta
how much are the roto packs
Supa Dexta
ebay 2nds are like 50 bux.
WarriorWithin
grumpysanta
make sure your tunnel is ok for the weight 7lbs per gallon
xf800spro
WarriorWithin
That setup looks awesome! The doo can is what gave me the idea for the rotopax. Want to go with the roto because I can get it in blue.
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
xf800spro said:I have a Doo can on my XTX and it is perfect, there when I need it and gone when I don't. Did a taillight relocate and a turn out works perfect.
X2 Only problem I had with mine is it leaks a bit out of the vent. I put a piece of plastic under the vent cap and stopped the leak. I torment my buddies about this because I tell them doo cant even make a gas can that holds together.
WarriorWithin
Just ordered my 2 gallon can and mount from rotopax so once I get it installed I will post up a few pics for everyone to take a look. ![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
burgerbone
I'll post my setup tomorrow, i keep forgetting.
