Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Hope your all enjoying your summer and saving the trail cash for winter.
I'm going to get into my sled this summer. I'm up there in kms now and looking for any input on high mileage preventative maintenance.
items on my agenda so far
- new track
- brake caliper bearing (again)
-chain case gears and bushing (again)
- re seal oil tank (again)
- slides and tri hub
- normal clutch cleaning and oil filter change
I've been thinking about checking the valve sets also.
Anything else?
thanks guys have a great summer I will take some pics of my findings as I dig in.
- new track
Anything else?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Lots of miles brother....keep us posted with pics of how things look when you dig into her.
I would think valves are fine at this time.
Dan
Dan
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I'm at 10,000 miles and i'll be doing the exact things as you.
1. new track
2. new top gear, maybe with different bushing
3. new chain case bearings
4. new brake side bearing with a fix to it
5. welded chain tensioner
6. new stub shaft bearing
7. rebuild my rear shocks & re-calibrate for my skinny (but tight) #*$&@
Obviously do the "tighten up" like Archie Bell and replace anything else on the way.
P.S. Archie Bell & the Drells sang the song "Tighten Up" in 1968
1. new track
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Great. Keep us posted what you find. I’ll be interested to see if the stub shaft bearing is bad? I never thought about it.I'm at 10,000 miles and i'll be doing the exact things as you.
1. new track
What do you mean “welded chain tensioner “?
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
https://ty4stroke.com/threads/keep-an-eye-on-your-chain-tensioner-idler-bolt.154568/
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Ok. I’ve seen this on a few machines that came through. I’ve been using loctite.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Loctite "should" work, but i'm not risking it. A small tach weld for peace of mind for me.
I'm only changing the stub shaft bearing cuz i'm taking it apart anyways to apply proper Loctite & i figure with 10,000 miles i might as well just change it.
Pstn head
Check the manifold to turbo pipe for cracks
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
All the checking stuff falls under the "Tighten Up", but i will add this to the extra attention list.
Oh ya, i'm going put some rubber under my fuse box.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
definitely have to practice safe fuse boxing.All the checking stuff falls under the "Tighten Up", but i will add this to the extra attention list.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Alright. She’s all tore down.
some things that where no surprise
-axle ruined again, got it machined and sleeved this time for a better fit
- upper gear in chain case ruined
Found one of the hoses above the track to cooler was leaking. Cheap fix but lots of work.
I checked the valves today. They are all bang on. No adjustement needed
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Did you have issues finding a machine shop to do the work to your drive shaft?
MS
MS
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
No, I’m lucky that way. Just need a good machinist, it’s not a real bad job.Did you have issues finding a machine shop to do the work to your drive shaft?
MS
